Austin/ round rock vagcom
yoda254
tx
2012 jetta tdi sedan
Just bought a 2006 jetta tdi and noticed that it had an aux input in the glove compartment but it doesn't work. From the research i've done, people are saying that it needs to be reset using vagcom. Would anyone in the round rock/ austin are be willing to help? thanks
kzoc
Austin
97 A3 Jetta 1.9 TDI, and 6 Volvo's!
If you would like to research the needed coding, and make the trip to S. Austin, you're more than welcome to use my VCDS.
Let me know-
K
yoda254
tx
Back again with needing help with a vagcom. My wifes 2011 touareg tdi has thrown the f20f4 and f207f (200 miles till no start) a day after adding def to the tank. I have taken the Adblue injector off and cleaned it in the hopes i can just do an Adblue reset and be back on the road. Delete will be worse case scenerio.
