Hi,
it all started back in February of 2023 when I first got my low oil pressure warning on the dashboard. I immediately turned the engine off and checked the oil level, on start up listened to strange noises but could not hear nothing concerning.
The low oil pressure warning continued to show up when the engine was still warning up (temp might have been around 70 degrees celcius) once every two days or so until the spring came, then it even got more rarer and when summer came it didn't show up at all. The last outside temp that the error show up was +10 celcius outside temp. It isn't logical that during winter when oil is thicker i have low oil pressure and during summer I had no problem with low oil pressure.
I have tested many oil pressure sensors, even the original one from Audi, all have failed after 2 days. Also tested the oil pressure from engine which was also OK. The engine doesn't seem to be leaking oil also. Only thing is that my intercooler pipe comes a little loose and spits a little oil to the coolant tank, but I think this isn't related with my problem.
The milage is around 249k miles, the problem started around 239k miles.
Any ideas to fix this anomaly?
