At which opening pressure did you set the dsla143970 injectors ?
I have R683 from bosio but need to find longer pins to up the pilot opening from 180 to about 240 bar.
Installing an adjustable throttle pedal bracket that keeps min throttle position at 1,8% keeps the idle stabilisation quiet and gets rid of idle shudder, 960rpm stable, also with aircon off :-D
Which flywheel and clutch are you running ? My search for a single mass unit didn't bring anything and I am affraid a new dmf with sachs performance clutch won't keep up for long either. Thinking of welding it together and using a sprung disc with sachs clutch.
Any problems with stretching headbolts, lifting heads with boost pressures of around 30 psi ?
There is not enough room for studs/nuts to clear te cams I fear.
I am running out of fuel when doing a 1/4 mile race, engine dies, air in the Vp44, also the swirl pot is almost empty. In tank pump is ok, dismantled it, not dirty. Tested it, delivered 320l/h @ 13,5v so ok.
Did any of you modify the fuel delivery system to the VP44 ?
B.R
