TDIsyncro
Many have been contributing to the CP 4.2 Bosch pump retro project. We are all thrilled you are back into your project Syncro!!!
Please back us up a bit......your rear suspension looks very serious!!!
Those tires look huge!!!
Certainly looks like shortened half shafts, special hub carriers, where in the heck are the springs / struts???
Must be some creative clearancing work!!!
Awesome!!
If you decide to run a CP4.2 pump, the Euro Ford pumps we all have seem to be missing the inlet and return line fittings.
I made up a bunch of fittings, here's a sneek peek!!
Basically a copy of the 2Microntech barbs.
Probably put a couple oring grooves on the next batch!!
All the best,
Andrew
Thanks Andrew.
I will tell a little bit about the rear suspension. I made use of upper and lower control arms from Audi A6, along with the hubs. These are connected to a custom subframe. The arms sit parallel to the road at this low ride height. The old wheel wells are gone and tub'd with aluminum. Coilovers with a custom spring rate, custom axles, the tires are a cheap sumitomo 315 rubber for set-up. WIll move to a good quality race tire after I peel these off.
