arp main studs
theman53
Holmes county ohio
01 jetta, 86 IDI TD
I have searched the forum, looking for info on the part numbers for the arp main studs for the alh. I see them on darkside developments, but no part number. I am close to summit racing and just want to pick them up.
WildChild80
Nashville, AR
2001 Jetta TDI 2000 Jetta TDI 2000 New Beetle TDI ALL 5 speeds
I think Kerma has them listed but not sure about a part number
Sent from my Pixel XL using Tapatalk
jwrb
Kent, United Kingdom
Caddy MK2 ALH, Cordoba Vario Cupra 1.9 High Power Build, 2011 Caddy 2.0 CR170
Kit #: 204-4706 for the head studs
Kit #: 204-5408 for the main studs (1.8t are the same as the 1.9)
WildChild80
Nashville, AR
ID parts has it listed as 5402
theman53
Holmes county ohio
01 jetta, 86 IDI TD
I wouldn't have thought the main studs were the same as all the old 8v engines. Thought they went about 15mm deeper? I will email arp if I have to, but ID parts is usually good, I didn't check there for some reason.
Markus L
Finland
Caddy (14D) 1.9TDI 2-stage 400+bhp, Passat 3BG 4motion AVF
I'm curious why do you want to install ARP studs.
theman53
Holmes county ohio
01 jetta, 86 IDI TD
I am building an engine. First TDI, but have made IDI's go fast. I don't know where I will be for power, but it will be at least 190 whp and it is going into a heavier vehicle than our MKIVs. I like the extra tensile that ARP has, might do a main girdle, haven't decided.
Markus L
Finland
I haven't heard of any ALH main bearing issues with ARL 12.9 bolts in up to 430 bhp builds - except in those that rev past 8000 rpm.
[486]
MN
02 golf ALH
well, those high RPM main bearing issues may be the oil pump cavitating, not the fault of the block's rigidity
ETA: another vote for "waste your money on something that will actually make you power"
Yourbuddysatin
Pennsylvania
2013 Jetta tdi
Sorry man I didn’t check to see if you replied hah.
This is just internals
1.9 alh bored to 2.0
BHW pistons
Rosten H beam roads with arp bolts
Stock main bearings
Stock crank with stock mains and arp main bolts
New oil pump/chain & sprokets
Hybrid alumina/steel oil pan
Alh oil squirters
AMC head with over sized intake and exhaust valves
Duel valve springs
Arp head studs
Colt stage 3 cam
Might be other things I forgot.
red16vdub
(617) City of CHAMPIONS
03 JSW 5spd
BHW pistons
Stock main bearings
Alh oil squirters
Duel valve springs
Arp head studs
Colt stage 3 cam
Good list .
Yourbuddysatin
Pennsylvania
2013 Jetta tdi
That list goes on and on for the rest of the golf the engine went into. Nothing feels better than to invest 7-8k into a $2000 golf..... all started from me finding a alh in the local junk yard for $150.
Yourbuddysatin
Pennsylvania
2013 Jetta tdi
No smiles yet as I haven’t finished it yet. It’s a major project/ restoration now. Shaved the engine bay, wire tucking. Blah blah blah
MrBigTruck
Kansas, USA
2000 Beetle, 2000 GTI ALH swap, 2006 Jetta, 2006 Jetta, 2008 Mercedes GL320 CDI
AMC head is a mistake. They don't last. I got 20,000 out of an ALH head bought brand new. Frank Irving can chime in on them but they're not the same alloy that VW uses so they just don't last.
jhax
Golden, CO
96 Passat B4V, ALH engine out of a 2002 Jetta, some IE Rods and ASV Pistons. Nothing drivable yet though
I'm about $10k or so into my MK2 ALH swap over the past 9 or so years, I've finished the motor a while ago and am awaiting paint. Still need to get the ECU out for tuning, I should be done in the next couple of months and then I will be able to enjoy that smile.
jhax
Golden, CO
Thats why you have at least two cars, Im dailying the Passat now, once the golf is done Ill daily that and get started on the passat.
Yourbuddysatin
Pennsylvania
2013 Jetta tdi
My golf will probably be a weekend garage queen. I have a truck and a mk6 that I drive plus my wife’s Touareg. Who knows when I’ll finish the dang thing anyways....
red16vdub
03 JSW 5spd
Totally disagree with you on the AMC Alh Tdi replacement head. I had a lifter come apart in one of my tdi’s, it destroyed a piston and head obviously. AMC was purchase new, which is well over a 100k miles and counting, on stage4 rc @ 28psi .
I also know of another person with roughly 68,000 on stg3 rc with AMC head .
When my OEM head let go, 2 Tdi guru’s gave the recommendations.
Yourbuddysatin
Pennsylvania
2013 Jetta tdi
Not sure who darkside had them supplied from but the exhaust are 33.5mm and intake are 37mm. When I bought the head I had them do all the machine work. I’m not sure what the valve springs were from either. I know the springs were a combo of 2 different stock valve train springs but not a clue what.
