Wanted to know if anyone is familiar with lift points in the front and rear of a 2012 Golf TDI with manual transmission for using a hydraulic floor jack to lift the vehicle before using jack stands? Thanks
For the rear, my jack fits under the spring mounts so I use those.
in the front I use the LCA rear mounts- sometimes a bit of fiddling to get the jack there.
I lift the rear from the center of the rear subframe, the front I have to do one side a time since the subframe is too far back to get a jack under and centered unless I drive up on ramps first
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
