Gulfcoastgolf
Like it states free stuff like removing intake sound canceling pipes or anything like that? I for one every time I get a new car I remove the engine covers so I can see the engine and watch for leaks or buildup of any kind.
Only because I like to see what going on and keep the engine, not just the covers clean. Yes I know it's not really a mod but it got my point out I think.Remove the engine covers????![]()
More often then need be more at random than anything else. I also wipe down everything I can reach every time I wash it.There isn't anything to see that you couldn't see during a normal service. How often are you opening the hood?
How do you do this? With VCDS or?disable the clutch start switch
Do you do this so you can move the car with the starter motor in a pinch?
Like that will be the first thing that will need replacing/fixing anyway...No force exerted on the crankshaft's dry thrust bearings at startup
Like that will be the first thing that will need replacing/fixing anyway...![]()
Not what I expected, but...thanks! My dad has a '69 911 he bought new the year I was born. I drove it some in my late teens. I had poured over the owner's manual as a child. When I was about 10, Dad mentioned that the starter could be used to move the car in 1st or R. Most of my cars have been manual but all required clutch pressed to start...but not the old Porsche. Since Dad's comment, I have wondered about moving a car with starter motor, but never have had reason or opportunity. Saw your post and wondered if this is what you had in mind. Cheers.No, my engines always start right up.
I use it to allow starting in neutral without pressing the clutch. No force exerted on the crankshaft's dry thrust bearings at startup, plus sometimes it is nice to be able to reach in and start the car without having to actually get IN the car. Like for servicing when the car is on a lift, etc.
If you already have (or know someone) with a compatible VCDS, then you have free mods available.Like it states free stuff like removing intake sound canceling pipes or anything like that? I for one every time I get a new car I remove the engine covers so I can see the engine and watch for leaks or buildup of any kind.
