bengone1
- Joined
- Oct 15, 2010
- Location
- Newport News VA
- TDI
- 1998 VW GTi 1Z powered. 06 Jetta PD. 01 allroad 6sp
cold air intake?
You mean the errors were caused by cold air intake?cold air intake?
It has happened before. The best way to tell would be to put the stock cold air intake back on and clear the fault codes (they all say "intermittent") and then see if they come back. If they do come back, it's not the intake. If they don't come back, it could be your intake. If you want you could try putting it back on again - if the faults come back, you know for sure what the cause is.You mean the errors were caused by cold air intake?
I haven't installed cold air intake yet, so I guess it is not the reason. ><It has happened before. The best way to tell would be to put the stock cold air intake back on and clear the fault codes (they all say "intermittent") and then see if they come back. If they do come back, it's not the intake. If they don't come back, it could be your intake. If you want you could try putting it back on again - if the faults come back, you know for sure what the cause is.
Have Fun!
Don
Yep, that's correct. Since all of the fault codes say "intermittent", I would recommend clearing them and then going for a drive. If they come back, you need to look further into them. If they don't come back, I wouldn't worry about it.I haven't installed cold air intake yet, so I guess it is not the reason. ><
That's what I thought. My guessing is, since the APR upgrade, of course there is a difference comparing now and then, therefor these error codes show up. I will clear them and recheck. How about ABS?Yep, that's correct. Since all of the fault codes say "intermittent", I would recommend clearing them and then going for a drive. If they come back, you need to look further into them. If they don't come back, I wouldn't worry about it.
Have Fun!
Don
Again, it's intermittent. Check tire pressure in all tires, then clear the fault and see what happens.How about ABS?
Thanks!I'll second the recommendation to clear the codes and see what comes back. If the torque difference codes come back again, you should speak with your tuner.
Any update on the codes/tune?Thanks to Don and VeeDubTDI.
After resetting, so far so good!
Eric
As far as I've read, APR is still having some difficulties with tune. Some guy on the Mk6 jetta section took off his tune because of it.Any update on the codes/tune?
I'm considering the APR as well.
Why did you not go Rocketchip?
Thx
That is correct, still seeing reports of issues. Malone and Rocketchip are your current options.As far as I've read, APR is still having some difficulties with tune. Some guy on the Mk6 jetta section took off his tune because of it.
APR is currently testing betta. Let's give them some more time and hope they will fix the problems!Any update on the codes/tune?
Thx
So far not. As I said I had major leak at oil cooler so they kept car for two days. I would think they scanned my car and forward this info to VW AG. I told service adviser that I have some mods on my car, like it dropped and ECU re-written for more power, well he said ECU may be will not cover but rest of it should not have a problem. I even talked them about turbo warranty extension, if it would cover with mods he said it should not effect warranty, unless turbo was modified or connector. Well generally I understood if it's sealed as factory, it covers. So my ECU is more likely not covered under warranty.phlfly: Have you had any drivetrain issues that were covered by VWoA warranty?
