Hot off the press!
Parts list for Gen 1:
Kits:
1K0-298-101-A (I believe this is the 2010+ kit)
Includes the Following:
Part Number Description
1K0-253-120-B Pipe for exhaust Circulation
1K0-253-725-F Clamp
1K0-253-115-AG Gasket
03G-131-547-H Gasket
2x N -106-421-03 Bolt - M8x25
3x 1K0-253-115-AE - Gasket
1K0-253-725 Clamp
1K0-253-691-J Exhaust Flap
2x 1K0-253-725-B Clamp
03L-906-262-N Oxygen Sensor
3x 1K0-825-951 Bolt - M6x20
3x WHT-000-729-A Bolt - M8x20
1K0-971-461-D Heat reflective mat
1K0-971-461-E Heat reflective mat
1K0-971-461-F Heat reflective mat
1K0-298-101-X
I believe this is for 2009 models
03G-131-525 connecting hose
03L-906-088-EG emissions temperature sensor
03L-906-088-J emissions temperature sensor
03L-906-088-T emissions temperature sensor
03L-906-262-B oxygen sensor before catalyst
04L-253-115-A gasket
076-906-051-A differential pressure sensor
1K0-131-552-A control line
1K0-131-552-B Control line with differential pressure sensor
1K0-131-649 bracket for exhaust pipe
1K0-253-144-BC bracket
1K0-253-463-AF bracket for exhaust system
1K0-253-725 clamp
1K0-254-708-GX exhaust pipe with particulate. filter.
1K0-971-461-C Heat reflective mat
3x 3C0-131-483-A spring clip
4B0-422-379 spring clip
5N0-131-783 shield for catalyst
5N0-971-461 heat deflector hose
N -010-335-13 screw, hex. hd.
2x N -015-081-6 shouldered hex. nut
4x N -015-083-15 shouldered hex. nut
4x N -023-002-15 hex. nut, self-locking
2x N -102-400-03 bolt, hex. hd. with shoulder
N -104-562-01 bolt, with polygon socket hd.
N -106-531-02 screw, hex. hd.
N -907-371-05 Oval hexagon socket head bolt
2x N -907-865-02 bolt, hex. hd. (combi.)
6x N -909-910-02 bolt, with polygon socket hd.
6x N -909-911-02 bolt, with polygon socket hd.
4x N -910-398-02 bolt, hex. hd. with shoulder
N -910-661-01 bolt, hex. hd. (combi.)
N -911-671-01 bolt,hex.hd.with shoul.(combi)
2x WHT-000-431-A bolt, hex. hd. (combi.)
