Neither the 02A nor the 02J that succeeded it were ever offered in a six-speed configuration. These are both five-speed transmission codes.
The nearest relative is the 02S, which is basically the 02J with a longer end case and a sixth gear stuck on the end. Eurotuning.cz also offers a kit to convert the 02A/J to this setup. It isn't any stronger than an 02A/J, but that's only important if you have big power modifications.
The most common six-speed to be swapped in is the 02M, which is a completely different transmission. It uses three shafts, which makes for a shorter length from flywheel to case end than the 02S, and allows the gearbox to use a different final drive for gears 5 and 6 than gears 1-4. It also uses a larger diameter clutch which handles more torque, and the box is also more torque-friendly. Unfortunately, it also uses different axles, the aforementioned larger clutch isn't compatible with the 02A/J setup (i.e. you'll need a new one), a more problematic slave cylinder which requires dropping the gearbox to swap, and a shift fork design which doesn't take kindly to ham-fisted shifting.
