Anyone need help,here I am(Dallas-Plano ,TX
WINDSORB4TDI
Nathalie
LOOKING
Marlin went out of his way to help me with a friends Gas powered beetle ecu, getting the Immobilizer deleted. Great guy and easy to deal with!
Vince
kcjettaman
Farmington, NY
2006 Jetta TDI
Spot-on Diagnosis!
Thanks for the correct diagnosis for my car trouble! You had it right on; EGR trouble. The garage I had taken it to said it was a bad cam; they were either incompetent or scamming me. Thanks Marin!
DDLTexan
Keene, TX
1997 & 1998 Jetta TDIs & 2000 Passat Wagon
2000 VW Passat Wagon
Marin - thank you, thank you!
I have been searching since 2006 for someone who I can trust and will do what they say. I have been lied to time and time again by other mechanics and delay after delay. I was depressed and discouraged and simply wanted to push the car over a cliff and be done with VW. I found Marin and gave him a chance.
He fixed the car, solved the codes that other mechanics could not, found out that the transmission place had squeezed a wire and damaged it and it was also setting off codes that could not be resolved until Marin.
If you want someone who really KNOWS about VW then give Marin a chance. He will do an honest job and not screw you over like many other mechanics have done to me.
Thank you Marin for being a man of your word and for being an honest mechanic in a world full of other lying mechanics. I will only use you and GLADLY recommend you to my friends and tell them that if they need an honest and knowledgeable mechanic - it is YOU.
Thank you for your help! Alan Weis
tikal
Southeast Texas
Hello folks:
This feedback is long overdue Marin. He has helped me in several occasions over the phone with my Golf. Now that I got a 'new' 2004 Passat wagon TDI I was able to make the drive and meet him in person to get a second key (it is scary for me to have only one key). Marin was very patient with me before making the appointment to explain to me how peculiar are VW remote keys for cars in the same year range and save me $. Meeting him in person just reinforced my good thoughts about his work ethics and skills. I had a great time talking with him and he also fixed right away the radio not working. He has great software skills and he can program your keys to do some fancy and very useful stuff!
I need to clone Marin and bring him to the Houston area :)
хвала !!!
cparagone
amston, ct
2005.5 jetta 2002 Golf GLS
Hi I'm not in your area but curious if its possible and what is needed to put half or full display in my 02 golf gls currently there is no display option
kosovo95
usa
mk4
Marin did an excellent job on my new MK4 cluster adaptation - I am in NY , so I just shipped him my original cluster and new one with sport faces ,got it back already , everything works perfectly , he made my new cluster with MFA and sport faces plug and play - for the fraction of a dealer's cost ! My GLI looks so much better now - I wish I knew about this professional earlier! Never thought it would be that easy and simple,
highly recommend his services to everyone.
Thanks again Marin!
Demon Diesel
Ontario
2007 Audi A4 Quattro Avant 2.0TDI 6spd manual
Thumbs up to some great work
Hey guys, just wanted to give Marin a thumbs up on his work. I'm doing a conversion on a 2007 Audi A4 from a 2.0T FSI to a 2.0TDI and wanted to swap out my cluster with a TDI one. IMMO on these cars is a real pain and I thought for sure I was stuck going to the stealer. After giving him my original file and the replacement cluster file he was able to quickly create the file I needed with all the key info in it (Keys, VIN, IMMO, Kms....) With full instructions from him it worked like a charm and exactly how he said it would go.
He also helpped me out with getting original files for my ECU after I searched for some time he was able to get them to me in only a few days!
Thanks again Marin. Keep up the great work.
carbajal67
mansfield tx
2011 golf
i just purchased a 2011 golf tdi and it only came with one key. I understand these need to be programmed if you buy a replacement. can you do this?
CNCTech
TX
2000 Jetta 178K, 2001 Jetta 228K, 99.5 Jetta (sold regretfully at 247K)
Bailed me out of a jam
Super helpful trusted TDI Tech, I had immobilizer problems over labor day weekend that would have left me in a BIG bind for the upcoming week if it weren’t for Marin. After scouring the forum for a way to get the immobilizer PIN I resigned to the fact that it wasn’t going to happen with VAG-COM software alone. I found Marin’s advertisement that he could reprogram or bypass the immobilizer system and emailed him at 10:00pm Sunday evening, he came out to my house the next day (Labor Day) and had me back up and running in 20 minutes! Can’t say enough thanks!
JettaNocona
Nocona, Texas
2002 Jetta GLS TDI;2013 Jetta Sedan TDI w/Premium
I have just purchased a 2009 Jetta TDI with 39,900 miles on it. The first two oil changes are on the dealership but I was wondering about the 40,000 mile service you spoke of at the beginning of the thread. It does have DSG. And I do not have any of the maintanince records for vehicle. I am taking it to the dealership on Tuesday the 18th of September for the first of the oil changes.
jetta 97
Dallas (McKinney) ,TX ,USA
2 X Jatta MK5 2006
I doubt that someone did 40k and trade in car right after that.
Garland, TX, USA
2010 Jetta
How to refill distilled water to battery
Hi Marin,
The battery on my 2010 Jetta TDI won't hold the charge. It's just been 3yrs old. The electrolyte is dim green. I want fill distilled water into the battery but don't know how. Should I buy new battery or try to restore this one.
You can email me your phone number.
audiphile
Irvington, NJ
shop full of swaps
Marin, thanks again for the cluster work. you're a magician, and your great work is much appreciated. The cluster is now installed and the car is ready for sale!
MarkU216
Fort Worth, TX
2006 Jetta DSG
He does great work for us
He has done great work for us (R Diesel Motors) on at least 5 occasions in Fort Worth. Recently brought back to life a broken cluster on a 98 Jetta.
Hello everyone.I live in Plano,TX. I have been Technician all my life. I come form Europe. I finish school in Europe in 1993. Start working when I was 16 .
I live in USA 11 years.I have been working on VW and Audi all my life(specially on TD-s & TDI-s). Also on BMW, Mercedes. I have Vag-Com and also have tool to Program keys up to 2007(MK4 and MK5) and Passat B5(2004-2005) ,able to Delete Immobilizer in ECU,and I have tool to replace Instrument Cluster and ECU (Used or new) up to 2007(this means if you have used cluster or ECU I can make it to work on your car).
I do provide complete work on those cars ( from oil change to check engine diagnostics,t-belt ,brakes , suspension, transmission service ,injectors , injection pump,etc.)
I am able to do ECU TUNING-TDTUNING Authorized Dealer.
On Golf, Jetta MK4 & MK5 or Passat B5.5 & B6 I can enable function "open -close windows via remote control"(http://www.youtube.com/watch?v=M4Wbrx1CdH8).
Also can turn off seat belt chime(you don't have ding,ding till you put your belt in buckle) and DRL can be turn off,also one touch on remote and opens all 4 doors(factory comes with dr.door open first than other doors).
Also I am able to enable needles light up with key on and light switch off (More info in post No.10)
On Full FIS and Half MFA clusters (Golf, Jetta MK4 & MK5 or Passat B5.5 ),
I can replace Cluster LCD Display when the pixels are bad or when they get shade and you can not see anything.
I use ONLY VDO Display and they are 100% same as original.
I have reasonable prices for my work and I do provide parts and warranty for my job.
So if anyone need something send me PM or e-mail me at
marinmm2001@yahoo.com.
I know it is very hard to trust to someone , and is hard to find good trusted mechanic ,but try me on little things and see my work.
ingramg
Lucas TX
2003 GTI 20th Anniversary TDI
Good Person & Mechanic
I got (Jetta 97) / Marin's information because User "Smileybug" from newbeetle.org pointed me to the Trusted TDI Mechanics - By State - TDIClub Forums list. I contacted him and advised him that I had a bad situation with a local mechanic who messed up a timing belt / head job which in turn I now had major damage issues with the engine due to him causing an intake valve to drop into the piston and the mechanic claimed the damaged piston was ok and that the head may be rebuildable and did not want to take responsibility he expected me to dish out more money. Marin said he would go with me as a Volkswagen specialist and help with diagnoses and try to get the mechanic to own up. He found that the cam chain tensioner was possibly damaged by mechanic, the piston which the valve dropped in to was no good, the cylinder had been damaged by the broken parts and the head was very badly damaged and may repairable, but would not be cheap to repair. Another engine may be the more economical approach? As of now the mechanic has offered if I get another engine to install new timing belt on it and remove old engine and install the replacement engine and eat all labor cost, but that would only be fair to me if I can get one at a decent price so we will see if not Marin said he would back me up in small claims if need be. Marin has been of very great help with assistance and knowledgeable information. Thanks Marin.
DDLTexan
Keene, TX
Marin - Thanks!
I was getting ready to leave on a trip a few months ago and my 2000 Passat car started acting up. Talked with Marin and he gave me a great suggestion. I did it and it fixed the car. I have had no problems and everything running well.
It has been a few months since he fixed my daughter's red Jetta 1998 TDI - it is wonderful and running soooo good. He fixed it when several other mechanics could not and also made more problems but Marin fixed it all wonderfully.
He fixed my 1997 black Jetta and it is running well and about 375,000 miles.
If anyone needs a great and honest mechanic - try Marin. He is great to work with and will give you honest feedback and great service.
Alan Weis
smketrny
Orange County, New York
1998 Jetta TDi, 2015 Passat TDi
Could not get my 2009 TDI Jetta to my local Guru due to time constaints. Will be in Dallas area next week. Can I possibly get an oil chnge?
jrip
Fort Worth, TX
Jetta, 2000, Blue, TOTALED, Jetta, 2002, Green
A shout out to Marin. Thanks for the injector pump re-seal. I brought my 2000 Jetta to Marin to help me find a water leak problem and in the process he pointed out that my injector pump was leaking. He found my water leak that I could not see and resealed the injector pump for me too. The car is running great and the pump is dry as a bone. Cya shortly for the clutch repair.
smketrny
LOVE this site!!!!!
Did not get a chance to get my 09 TDI to my local Guru (Hevster1). While driving cross country, I wanted to get my oil changed. So sent Marin a PM and got into Dallas this morning. Took the car right in, changed the oil and fuel filters. Took complete fuel filter housing out and cleaned it, explained it to me in lounge area (standing at door like expectant dad.....lolol) why he took it out and did what he did.And even set my key up for the windows. Checked other things like tire pressure, serpentine, etc. Also did cabin filter. FAST, THOROUGH and PROFESSIONAL.
BOTH gurus are top notch. This site is the best for great service at great prices. Not many people you can trust, but guys like a Guru who love cars and make sure they run right makes trusting mechanics a little more secure when dishing out $$$ on out TDI's.
Was a pleasure to meet you and do business with you, Marin. The recommendations previous were on the money. My trip cross country will be much more confident with no problems.
Shafsandaluk2012
Newcastle upon tyne
Mk5 1.9 2004
Hi everyone I am new to this site need some help an advice
a think this might be the right place after reading some intresting posts i see jetta 97 may be able to help
Hi everyone need some help with my mk5 golf 1.9tdi
Hi everyone I am new to this site an not sure how to really use this site so please point me to the right direction if I am lost
Right to start with how is all you tdi owners copin with your cars as I am sick to death with mine tryed to everything still no results. Can anyone help me as I am having issues with my mk5 golf 1.9tdi 2004 bkc model.
The problem is the car battery drains out after every few day. Had the battery and alternator tester put on an they ok but there is a drainage some were does anyone else have this problem. Thanks an hoping for someone to save me from having to sell the car as I do love it as it is my first car which I have had for like 2 weeks
Thanks guys
