hutchman
- Joined
- Sep 6, 2005
- Location
- Virginia
- TDI
- 2006 Jetta TDI Pkg 1, 5 Spd, Graphite Blue / 2002 Jetta GLS, Black w/tan leather
After a week of good progress (TB change, rear rotor and pad replacement etc.) I decided to do the diesel purge thing.
Half way through the can bubbles started to appear in the little clear filter I was using and the engine started to jump so I turned it off and now I can't get it started again.
I can pull fuel from the return so I'm not quite sure what to try. It isn't exactly like you can crack the injectors to bleed them or if you can I don't know how. Haven't found Bently to be much help.
Thanks!
Thanks!
