Got a 2006/7 passat b6 1.9 tdi BKC with same issue, new map sensor-no change- boost is stuck at 2193mb...wiring is good but i get weird pulses on map wires. Changing ecu tomorrow as it looks like its been mapped at some point....
Any suggestions? Here is the scan...
Monday,29,November,2021,15:33:58:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 21.9.0.2
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: XXXXXXXXXXXXXXXXX License Plate:
Chassis Type: XX (3C0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 53 56
VIN: XXXXXXXXXXXXXXXXX Mileage: 399510km-248244miles
00-Steering Angle Sensor -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 021 AN HW: 028 101 208 5
Component: R4 1,9L EDC G000SG 7004
Revision: --H01--- Serial number: XXXXXXXXXXXXXX
Coding: 0050071
Shop #: WSC 00028 028 00001
VCID: 6BDF9A6E4A85F9D184-803E
VINID: A28A28A28A28A28A28A28A28A0617BF560
5 Faults Found:
000567 - Manifold Pressure / Boost Sensor (G31)
P0237 - 000 - Signal too Low
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.44 V
Bin. Bits: 00001000
Absolute Pres.: 1081.2 mbar
Absolute Pres.: 2182.8 mbar
000280 - Engine Coolant Temp. Sensor (G62)
P0118 - 000 - Signal too High
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.52 V
Bin. Bits: 00001000
Temperature: 28.8°C
Temperature: 28.8°C
005658 - Glowplug for Cylinder 1 (Q10)
P161A - 000 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00001100
Temperature: 1.8°C
Bin. Bits: 00110000
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 000 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00001100
Temperature: 1.8°C
Bin. Bits: 00110000
005661 - Glowplug for Cylinder 4 (Q13)
P161D - 000 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00001100
Temperature: 1.8°C
Bin. Bits: 00110000
Readiness: 1 2 0 0 1
Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 K HW: 3C0 614 095 K
Component: ESP 440 C2 H014 0001
Revision: H014 Serial number: 0657065082
Coding: 0013569
VCID: 2A515F6A85FF20D93F-807E
2 Faults Found:
01200 - ABS Valves Supply Voltage
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 1
Fault Frequency: 70
Reset counter: 117
Mileage: 399501 km
Time Indication: 0
Date: 2000.00.00
Time: 00:47:02
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 117
Mileage: 399511 km
Time Indication: 0
Date: 2000.00.00
Time: 19:56:31
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 K HW: 3C0 907 044 K
Component: ClimatronicPQ46 041 0101
Revision: 00041003 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 2953A06680F92BC136-807C
1 Fault Found:
01273 - Fresh Air Blower (V2)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 157
Mileage: 399501 km
Time Indication: 0
Date: 2000.00.00
Time: 00:01:09
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 J HW: 3C0 937 049 J
Component: Bordnetz-SG H37 1301
Revision: 00H37000 Serial number: 00000002156717
Coding: E1888F0700041A00000A00000F00000000095D435C0000
Shop #: WSC 05311 000 00000
VCID: 30654D02A3235A09F1-8064
Subsystem 1 - Part No: 3C1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 100107 022 0601
Coding: 00046997
Shop #: WSC 05311
Subsystem 2 - Component: Fehler Lin-Slave 02
10 Faults Found:
01504 - Bulb for License-Plate Light (X)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 117
Mileage: 399501 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 10.65 V
ON
ON
OFF
OFF
OFF
02394 - Parking Light Left Front (M1)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 117
Mileage: 399501 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 10.65 V
ON
ON
OFF
OFF
OFF
02395 - Parking Light Front Right (M3)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 117
Mileage: 399511 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 11.60 V
ON
ON
OFF
OFF
ON
02071 - Local Databus
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 117
Mileage: 399501 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
OFF
OFF
OFF
01496 - Bulb for Fog-Lamps; Left (L22)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 117
Mileage: 399501 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
OFF
OFF
OFF
01500 - Bulb for Fog-Lamps; Right (L23)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 117
Mileage: 399501 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
OFF
OFF
OFF
01049 - Supply Voltage Term 50
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 117
Mileage: 399501 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 7.45 V
OFF
ON
ON
OFF
OFF
01520 - Rain and Light Recognition Sensor (G397)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 117
Mileage: 399501 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.10 V
ON
ON
OFF
OFF
OFF
00154 - Windshield Wiper Motor; Passenger Side (V217)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 157
Mileage: 399501 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 9.45 V
OFF
OFF
OFF
OFF
OFF
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 157
Mileage: 399501 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 9.45 V
OFF
OFF
OFF
OFF
OFF
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 A HW: 3C0 909 605 A
Component: 0B AIRBAG VW8 028 2321
Revision: 06028000 Serial number: 0034ZS1RT367
Coding: 0012354
VCID: 244DB152E7DBF6A905-8070
Subsystem 1 - Serial number: 6332MSMEE1439680
Subsystem 2 - Serial number: 6342MSME26F36580
Subsystem 3 - Serial number: 6351HTS62M7EQNI2
Subsystem 4 - Serial number: 6361HTS62M7E25L2
Subsystem 5 - Serial number: 6371VTS63UE5P482
Subsystem 6 - Serial number: 00000000000000000
No fault code found.
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Part No SW: 3C0 953 549 A HW: 3C0 953 549 A
Component: Lenksäulenmodul 004 0010
Revision: 00004000 Serial number: 3C5953507B
Coding: 0000011
2 Faults Found:
00446 - Function Limitation due to Under-Voltage
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 850 G HW: 3C0 920 850 G
Component: KOMBIINSTRUMENT VD1 2926
Revision: V0018000 Serial number: 00000000000000
Coding: 0006105
Shop #: WSC 10124 599 88555
VCID: 254BAC56ECE10FA112-8070
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 157
Mileage: 399501 km
Time Indication: 0
Date: 2000.00.00
Time: 01:07:41
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 157
Mileage: 399511 km
Time Indication: 0
Date: 2000.00.00
Time: 19:56:19
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 1K0 815 071 H
Component: Zuheizer 031 1312
Revision: A Serial number: 09010046
Coding: 0000012
4 Faults Found:
01408 - Under-Voltage Shut-Off (fixed Value)
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 34
Reset counter: 150
Mileage: 464638 km
Time Indication: 0
Date: 2000.00.00
Time: 20:47:12
Freeze Frame:
Malfunction
Temperature: 2.0°C
Temperature: 2.0°C
01406 - No Flame
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 244
Mileage: 377156 km
Time Indication: 0
Date: 2000.00.00
Time: 22:10:52
Freeze Frame:
Start
Temperature: 30.0°C
Temperature: 20.0°C
00003 - Control Module
014 - Defective - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 244
Mileage: 377156 km
Time Indication: 0
Date: 2000.00.00
Time: 22:10:52
00664 - Fuel gauge
Freeze Frame:
Fault Priority: 0
Fault Frequency: 26
Reset counter: 150
Mileage: 399016 km
Time Indication: 0
Date: 2000.00.00
Time: 20:54:28
Address 19: CAN Gateway Labels:. 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 A HW: 3C0 907 951 A
Component: Gateway 006 0010
Revision: 00006000 Serial number: 0500C052080573
Coding: 3D3D0C04CA1002
VCID: 1F47BEBECEBDD57158-804A
1 Fault Found:
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 117
Mileage: 399511 km
Time Indication: 0
Date: 2000.00.00
Time: 19:56:20
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 HW: 3C0 959 433
Component: IMMO 038 0364
Revision: 00038000 Serial number: 00000000000000
Shop #: WSC 130939 1023 786430
VCID: 67D7E65E566DDDB1E0-8032
Subsystem 1 - Part No: 3C0 905 861 C
Component: ELV 023 0350
3C0905861C ELV 023 0350
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2341
Coding: 0000181
VCID: 36697B1A41477439AB-8062
1 Fault Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.12 1502
Address 46: Central Conv. Labels:. 3C0-959-433-46.clb
Component: KSG PQ46 ELV 038 0453
Coding: 00900A0801860E763804941570084F09603D00
Shop #: WSC 08224 974 890308
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
2 Faults Found:
00122 - Outside Warning Light/Door Exit Light; Rear Left
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00111001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 157
Mileage: 399501 km
Time Indication: 0
Date: 2000.00.00
Time: 01:22:07
Freeze Frame:
Fault Status: 00110010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 157
Mileage: 399511 km
Time Indication: 0
Date: 2000.00.00
Time: 19:56:20
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0000180
VCID: 3777761E464D8D31B0-8062
1 Fault Found:
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 012 0001
Revision: 012
Coding: 0000012
VCID: 2143B846F8C9E3816E-8074
3 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 157
Mileage: 399496 km
Time Indication: 0
Date: 2000.00.00
Time: 01:06:31
Freeze Frame:
Voltage: 8.28 V
Count: 202
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 157
Mileage: 399504 km
Time Indication: 0
Date: 2000.00.00
Time: 19:56:06
Freeze Frame:
Voltage: 7.76 V
Count: 200
02844 - Lamp for Automatic Parking Function
009 - Open or Short to Ground - MIL ON
Freeze Frame:
Fault Status: 11101001
Fault Priority: 4
Fault Frequency: 18
Reset counter: 117
Time Indication: 0
Freeze Frame:
Voltage: 10.25 V
Count: 64
Address 56: Radio Labels: 1K0-035-1xx-56.clb
Part No: 1K0 035 195 A
Component: Radio BVX 006 0013
Coding: 0040400
5 Faults Found:
00856 - Radio Antenna
011 - Open Circuit
00874 - Treble Speaker Front Left (R20)
00875 - Treble Speaker Front Right (R22)
00872 - Bass Speaker Rear Left (R15)
00873 - Bass Speaker Rear Right (R17)
