chief poncho
I'll say it one more time. The difference is due to the adjustment to the minimum $5,100 Restitution. If your base restitution is $5,100 or above then your calculation works perfectly because it contains BOTH the mileage adjustment for the vehicle value and the mileage adjustment for the restitution value without counting it twice. Keep in mind. If you were only doing the fix, the amount you receive for the "Modification/Restitution" value is adjusted by the mileage. You don't get to dip into that adjustment twice when that value is below $5,100.
Here is your specific example if you had taken the fix. (assuming it would ever be offered).
Modification Base => $4636.73
Mileage Adjustment => $4636.73 + $50 (right out of the tables)
Mileage Adjusted Modification Value =>$4686
Since $4,686 < $5,100 you get $5,100
Here is what you are asking VW to reimburse you for the restitution portion of your buyback.
Modification base adjusted to $5,100 + $50 mileage adjustment => $5,150
Like I said, even though it isn't explicitly defined in the tables, the $300 mileage adjustment is split between the vehicle and the restitution. $250 is applied towards the vehicle value and $50 towards the restitution. If you're above $5,100 it doesn't factor into the calculation because they don't give it to you twice. If you're below $5,100 it only gets factored into the calculations once. And as I stated, the lower your restitution value, the greater the adjustment, and thus the difference between your two offers. Also like I said before, I understand your logic, but it's flawed. The settlement paragraph does not address the calculation for the "restitution adjustment" which is exactly where your missing $50.00 goes. That calculation is not in conflict with the quoted paragraph.
