Do it! Do you have the car already?
If not, best bet would be a v6 5spd or w8 6spd 4mo car. For gearing, if it's a 6 spd 01E you can get the .56 6th gear from Scott DeWitt and you'll be golden. If it's a v6 car that was lucky enough to get a 5spd 01E instead of the 01A, you can convert it to a 6 speed with the proper 6th gear. If it's an 01A, you can run it for now but the rpms will be a little high; most durable bet would be to swap to a 01E.
As for electronics and motor, a wrecked b5.5 would be the easiest to start with as that would make it plug and play.
