Anyone considered a Miller cycle?
darkscout
Grammar Scout
Michigan
2003 Golf
Just wondering if anyone has worked out the math for doing a Miller Cycle on their TDI. It would require custom cams and 2 turbos (low and high pressure)
darkscout
Grammar Scout
Michigan
2003 Golf
Sounds like you would have to have a supercharger or low end performance would suffer.
Or you size your sequential turbos so that it is pushing boost at idle.
Also, you might have issues with valve to piston collision with the changes in intake valve timing.
How would you have that? The piston is still near BDC. It's not like you're cracking the intake valve at TDC. You leave the intake valve open for a small portion of the compression stroke. You do all the 'compression' in the turbos that way you can extract the heat from it. (Unlike doing it in-cylinder)
GoFaster
Moderator at Large
Brampton, Ontario, Canada
2006 Jetta TDI
It certainly won't be a "performance" mod. It will reduce torque below standard at lower revs.
The other thing with making the effective expansion stroke longer than the effective compression stroke (that's what happens with late intake valve closing), is that there will be less energy left in the exhaust gases to spool the turbo up.
There's a reason Mazda did this in conjunction with a supercharger rather than a turbo (on a gasoline engine). There's also a reason that they don't do it that way any more.
The non-forced-induction Atkinson cycle has the same effect; lots of hybrid cars use it; quite a number of gas engine cars with VVT use it to emulate the Atkinson cycle when running at part load. The hybrids use the electric powertrain to fill in the missing low-end torque.
diesel + atkinson/miller + turbocharging => probably not very happy.
