Any issues with running 205/65/16 vs. 205/55/16?
sullystull
WV Mountains
2011 JSW 6spd manual
A buddy has a nearly new set of bridgestone blizzak winter tires for sale. They are 205/65/16 instead of the stock 205/55/16 tires. Would there be any differences/issues with running this new size? I can pick them up for a fraction of the cost of new ones. Thanks,
NITRO330
Wisconsin
2013 Passat TDI SE
Also, not that it's the same, but I ride a Honda Valkyrie and guys run anything from a 205/55 to 205/65 16 with no problems.
740GLE
NH
you might run into rubbing issue if the rear is loaded down with gear, but a couple members here run 205-60-16's with no issue. Next set of rubbers i'll be looking at either 205-60-16s as they are cheaper than the 55's and i enjoy the bigger side wall.
Vahoagie
Ashburn Va
2011 JSW 6-speed manual TDI.Owned 1980 diesel rabbit back then.
You'd change the overall height of the tire by more than 1.5". When speedometer reads 60mph (96.6km/h) actual speed will be 63.8mph (102.7km/h): 6.3% faster. And your odometer would be off.
http://www.rimsntires.com/specs.jsp
The real difference is only half of the height since you have 1.5" /2 on top a nd on bottom. You would really be loading heavy to get a rub
Hoagie
WVU TDI
Beckley, WV
2013 Passat SE 6m
Hoagie
Haha, what? You think the bottom half just sinks into the ground or something?
ToeBall
Houston, TX
2010 VW Jetta Wagon TDI
There are bump stop spacers available from the parts counter for the rubbing issue and the speedo can be recalibrated with vag-com, though even on the max setting you'll be slightly off (less than 2% though). I'm running 255/40R18's on my car which are almost as tall.
sullystull
WV Mountains
Thanks for all the the great feedback. I may roll the dice and go ahead and purchase the tires. They'd only be on the car during the winter months.
BrShootr
Utardia
MKVI JSW
Really? You don't see what's happening here? 1.5in bigger tire will be .750" closer to the car, as the car will be raised .075" from the ground. The DIAMETER changes 1.5", so the RADIUS will increase by .075" and therefore the tire is only .075" closer to the car.
It is worth noting that you can use the snow tire setting on the MFI to compensate for the larger tire.
ToeBall
Houston, TX
I think you missed an order of magnitude there.
WVU TDI
Beckley, WV
2013 Passat SE 6m
Re-read. I'm guessing you guys are talking about tire gap / ride height, initial point was about tire height.
Also, 1.5 / 2 = .75, not .075 :)
tditom
san antonio & austin
Hoagie
My post was not addressing the wheelwell clearance- only speedo and odo error.
