Any cheap fix for sagging hood insulation?
relumalutan
Michigan
06 Jetta TDI Special Edition
Welding wire. Grab like a 2-3 ft. section, bend it in the middle and insert the ends deep in the hood holes where the ending tabs of the insulation used to go.
backfast61
Mechanicsville , VA
2006 VW Jetta TDI automatic,2006 VW Jetta TDI 5 speed
I believe that the actual clips that hold it up are available online... easiest way to fix it properly. I believe that it is definitely needed as a sound dampener ...absorbs some of the engine noise.
Guttboy
Colorado at 7500'
Jetta MkV 2005.5 Platinum Gray/Gray Leather Pk2
After several mouse "houses" in ours as we keep it outside now, I bit the bullet and just bought one and the clips a bit ago. Under $200 for us out the door.
