hid3
Banned
kcfoxie, any ideas where/how to get TDT in Europe?
Anyway, does anyone know oil capacity for BEW engine?
Get the 8000 lb version of these. They work great for the low clearance of the Jetta. You can get them at most auto parts or discount chain stores.ssamalin said:I I'm getting wheel stands and changing it in a parking spot, possible?
Jason, I believe you underfilled your customer's car. As far as I've searched (Bentley forums, Tdiclub forums, local UK forums) I found that BRM (also his Eropean twin brother BLS) takes 4.5 quart of oil if you don't suck out the oil cooler and do a bottom drain. If you suck the oil from oil cooler too, then you have to fill with 4.75 quart of oil.jasonTDI said:Drain from the pan and filter replacement without emptying the oil cooler is 4 qt's to the middle of the hatch marks. I usually fill 4.25 since customers don't check....ever.
ROFLMAOjerry_m said:Jason, I believe you underfilled your customer's car.
What's so funny about it?Windjammer said:ROFLMAO
You're the expert because you read about it.jerry_m said:What's so funny about it?
jerry_m said:Jason, is 4 quarts what Bentley (or other manual) says?
Do you know what oil capacity is for BEW?
The reason I'm asking is that 4 quarts is quite low. Here in Europe (almost) all PD engines with flat tappets take at least 4.5 quarts per book. However, BKD engine (which is 2.0 TDI-PD 16v and use roller type followers [and of course doesn't suffer the cam wear problem although have others]) take exactly 4 quarts.
Might that be one of at least few factors why BRM suffers cam failure?
Hi dude!hutchman said:This site is way better than cable!
Look at how many people here put 4.5-4.7 quarts.40X40 said:It is funny because you always seem to find a guru or someone of many years experience to try to correct or 'wonder' about whether they know what they are talking about.
The people I am talking about have impeccable credibility here. Now, these people are not infallible, but they have long glorious track records... which you, umm, don't.
Therefore: ROTFLMAO
Bill
If it isn't too short/longDPM said:the right amount is whenever the dipstick says so, no?
ROTFLMFAO!!!!40X40 said:There is an oil company advert that comes to mind at the moment and it quite appropriate.
Think with your dipstick, Jerry!
Bill
oilhammer said:ROTFLMFAO!!!!
I think that guy is possibly from the UK too!!!! (or supposed to be, anyways).
