Turbo Steve
- Joined
- Jan 11, 2000
- Location
Unlike the A-3 TDI's, VW has installed an anti-shudder valve in all A-4 diesel engines, which was designed to eliminate the little shake and shimy that sometimes is felt by the A-3's (for a 1/2 second) right after the TDI engine is shut off.
The Robert Bentley Manual uses the term - "Intake Manifold Change-Over Vacuum Control Valve", but I prefer to simply call it the Anti-shudder Valve, which is a more simplified desciption of its purpose.
In the 2000 Edition of the RB Manual (page 23-19) we read:
"The intake manifold change-over valve is a flap valve that closes for approximately 3 seconds when the engine stops, blocking the air to the engine. This reduces the suddenness of the diesel-engine shut-down. The valve re-opens once the engine has stopped."
Lubrication of the shudder valve's actuator rod as it enters the small vacuum valve is wise to do on a periodic basis, i.e. each LOF change.
[This message has been edited by Turbo Steve (edited December 04, 2000).]
