dqa
The stock antenna mast from my 99.5 Golf is getting ratty. Figuring all recent VW antennas are probably interchangeable, I ordered one from Amazon for ~$30.
It turned out to be part 1J0 035 849E , listed on the VW label as "VAR.ANTENA" It also turned out to be about 2.5" longer than my stock antenna (47.5cm vs 40.5cm - if you count the screw I suppose it would be about 48 and 41).
- Am I wrong to think that antennas should be more or less identical in length, or multiples of each other, since the best reception is at multiples of the typical wavelength?
- What is the proper part number for my stock antenna mast?
- Are there shorter antenna lengths (other than the stubby ones) that I should consider? What are their part numbers?
