Garage door malfunction knocked off my antenna. Found a clean replacement base from a 02 Jetta at the junk yard. The connector from the base to the cable was under a foam piece attached to the roof. Trying to install the new base in my 03 Golf and the connector cable seems to route itself to a heavy duty plate above the hatch with no easy access to remove the plate and make the connection Anyone dealt with this ? Were there some changes in the later model MK4's for routing of the connector cable? Any and all help greatly appreciated .
Thanks,
Studs
Thanks,
Studs
