bhtooefr
The TDIClub Forums have a search function that allows one to easily locate threads, without having to dig for a long time to find a relevant thread. One should use it BEFORE asking a question - if your question has already been answered, it saves everyone a lot of time to look it up.
However, the searching system that is in place on these forums is known for being difficult to use. Unlike a search engine like Google, locating relevant content is difficult. Part of this is because of the way the search engine here works - it sorts the results by how old they are, not how relevant they are. Also, it assumes that either word is acceptable, whereas a normal search engine assumes that the searcher wants documents with BOTH words.
Before starting a new thread, click the search link:
When clicking it, a menu will come up. This menu will contain a search field, and an "Advanced Search" link, like so:
Click that link, and you will get the "Advanced Search" page. This page will include the following element:
Note the circled "Boolean" button. Whenever you are searching these forums, you will want to click on that.
When searching, it helps to be as specific as possible. If you know what section to search in, tell it to search in that section. If you know who posted the post you're looking for, put their username in the "Search for Posts by User" field. If you know how long ago it was posted, you can adjust the time range.
To look for multiple words, you use the words AND, OR, or NOT between the words. AND makes it such that both words are required, OR makes it such that either word can appear, not necessarily both, and NOT makes it such that the word following it cannot appear. Do not attempt to put + or - before a word, as it will not work.
Below are some examples of searching for posts containing the words diesel and pollution, but not nitrogen.
This screenshot depicts a search that an average user may try to use. He or she tried to use the +es to signify that a word should appear, and the -es to signify that a word should not appear. Attempting to search using this method will most likely be fruitless.
This screenshot depicts a search that will likely find the relevant posts quickly and easily. First, the user used the Boolean keywords (AND and NOT) to tell the search engine what to do (and enabled the Boolean option). He or she also focused the search - such a topic would likely be found in the TDI Emissions section, so the search can be restricted to there without worry that important information is being missed.
Hopefully this guide helps with your searches on the TDIClub Forums!
