Installed mine this weekend. I have one warning for you. If you are using a 2 foot long torque wrench and set it to 20 ft/lb (it's lowest setting) for the pot metal frame studs (supposed to be 15 ft/lb) you will twist that sucker right out of the frame
Yep, the other three got just snugged with a normal short ratchet.
Only other small setback was that the two flat nuts that go onto the threaded studs were not machined all the way through. The threads stopped just short on one side of both nuts. I pulled one of the studs back out, put it in the vice, and finished cutting the last bit of thread on the nuts with a wrench. No biggie
I forgot to pay attention to the alignment of the three torx screws at the back with that of the panzer. As a result I couldn't put my plastic pan back on unless I wanted to loosen it all up again and re-align. I think I'll just leave the plastic pan off...
