burpod
teh stallionz!!1
- Joined
- Nov 27, 2004
- Location
- cape cod, ma
- TDI
- 82 rabbit vnt ahu, 98 jetta vnt ahu, 05 parts car, 88 scirocco.. :/
i was going to post a more detailed thread involving this, but currently just trying to figure out this issue and get some ideas before i pull the pan off again or take the head off.
my ahu, that previously skipped a timing belt, i rebuilt with forged rods, asv pistons, machined i-shaft, new ported head and rebuilt at machine shop. after some relatively minor issues that i resolved, car was running great, loads of power, and after 2800mi on it, i was starting to really push the boost and fuel, thinking i was good to go. after a hard run, lost boost, 15 seconds later bad groaning and strainging sounds, pulled over. then i looked at my oil pressure gauge and it was 0. shut it off. still oil in the dipstick so first thought was i-shaft broke. i thought engine was toast. went back with my flashlight and checked vacuum pump and sure enough, i-shaft had broke, the end at the vac pump was loose.
following day i got the courage to check a cam bearing, and to my surprise it looked perfect, so did the cam and lifters. so pulled them pan, everything looked fine, engine turned over nice and smooth as it should. some little nick marks on the bottom of rod #4 where it had been hitting the now loose i-shaft, no longer rotating with the tb. discovered the i-shaft sheared off right at the beginning where it had been machined down. with the stress of the belt it also spun the outer bearing, and the TB was all messed up. however, before removing the belt etc, i did verify timing was still spot on! phew! i was beginning to think i dodged a bullet and perhaps could get away with making a new i-shaft and putting it in, despite seeing some nicks on the bottom of rod #4. since the shaft was loose at that point, perhaps i wrongly thought it would be OK.
put in a new outer i-shaft bearing (inner one looked fine). so made a new i-shaft on my homemade "lathe" (more on that later), verified it wasn't hitting anything, got it all together, including wasting 3 hrs dealing with a motor mount bolt that broke while tightening it. fired right up, i can't say for sure but thought i felt a couple hiccups during the first few seconds. got my timing to just below the middle line (so when warmed up it would likely be just above). seemed to sound OK, i don't think it was making the very loud metallic pang/tapping sound at first. so took an easy 8 minute test drive. a number of times it would suddenly lose boost, like the n75 just quickly closed (or opened, what i always get it mixed up), letting out a little woosh. i think i saw some vacuum fluctuation on my vaccuum gauge, but it's not mounted and just hanging around in the dash so was hard to tell for sure. but it sounded like a momentary loss of vacuum, and then would start boosting again fine. when i got back after the engine was warmed up, checked timing with VCDS again, just above the middle line, and noticed it was making a very sharp tapping/panging sound from the head. like ball peen hammer on an anvil i guess i would describe it. very metallic. goes up with RPMs and very distinct.
long story short, i've checked all these things:
-oil pressure seemed normal as i drove it, went up and down with RPMS, was about 75psi when i first started it, warm 75F day
-verified physical timing again, spot on.
-tensioner looked good
-all other pulleys look and feel good
-checked glow plugs and injectors, no leaks around the base.
-loosened each injector line as it was idling, sound still there, just started to sputter when injector lost pressure
-i couldn't depress any of the lifters by hand
-no exhaust leaks
-no other funny sounds or stupid little things like loose heat shield that i could find
-inspected end of i-shaft at vac pump - looks perfect, no evidence of collision, same with outer end of the shaft, bearing looks perfect
-took cam out, all lifters look perfect, they all rotated, cam looks perfect
-without taking more out, the springs and upper retainers all look and feel normal
--however, even after engine had been sitting overnight, i cannot compress any of the lifters by hand. i though they were supposed to drain out after a few hours? i noticed this when i rebuilt the engine before.
could these lifters be bad? too much oil pressure in them?
dreading having to take the pan or head off again, but i'm running out of ideas.
i've read injector pumps when going bad can make a loud ticking sound, but this is much more of a sharp PANG, TAP sound and really sounds like its coming from the head. not as loud underneath the car or putting my head up to the oil pan. the car was also running perfect just prior the i-shaft breaking.
any ideas? if i get motivated i was going to post a better thread on the trials and tribulations, but wife is fed up (so am i) and just want to get it running again because i have a million other things i need to be doing....
-no exhaust leaks
