kybishop
Not having much luck.
I started this in the glow plug/relay sticky but it has now run off the glow plug topic.
1998 Jetta TDI. Two winters ago when I first got it had trouble in the cold temps. New glow plugs, new fuel filter and advanced timing by Paramedic and it ran flawlessly the rest of that winter. Ran flawlessly last winter.
First cold snap this winter and it would not start. Glow plugs were bad, I replaced. Still no start. Checked voltage at glow plug harness and all four checked okay.
I replaced fuel filter and still no start. It would empty the fuel filter each time so I was then going to chase a fuel leak.
55 degrees today, quite the warm spell from -2. Replaced the Thermostatic Valve on top of the fuel filter. No start. I then tried to run it from a jug of diesel to the filter to eliminate any problems with fuel pickup or connections from filter back to tank. Still no start.
I am not sure where to go from here other than a trip to Paramedic. Not wanting to tow though so would rather get it running here at home.
Thanks for any advice on which way to go. I have good voltage at the glow plug harness on all four. May have to chase down fuel connections or vacume connections?
Only thing I changed since the no start the first time; Glow plugs, fuel filter, air filter and thermostatic valve. Any chance that fuel filter could be faulty and pulling in air? I had two filters, one off brand which is the one I put on and is on now. The other is a Bosch that I had planned to use next.
