another new oil from vw
vwrobert51
Maui Hawaii
2004 Jetta Wagon
just to pass this along, new VW tech bulltin. states new v-10 TDI with bluetech and urea systems WILL require this oil VW 50400-VW50700 LOW ASH OIL ONLY! new p/n GVW 052-195-M2 also all future TDIS with this system will require this oil, oil is just comming out to dealers now, should be in stock by summer. :cool:
bhtooefr
TDIClub Enthusiast, ToofTek Inventor
Newark, OH
None
Can't wait for the "505.01 is a conspiracy" brigade to start complaining about this. :rolleyes:
(Not like we didn't know this was coming, the V10 TDIs already said 505.01 or 507.00...)
dieseldorf
MA
ex- 1996 wagon, ex-2000 Jetta
Robert, thanks for stepping up and sharing relevant info!
BleachedBora
Gresham, Oregon
'81 DMC-12, '15 GL350 CDI 275 hp/448 tq - '81 Caddy CJAA, '05 E320 CDI 250hp/450 tq, '23 ID4 AWD Pro S Plus
Old news :p
It's for Treg only, all other PD's are still 505.01.
-BB
GoFaster
Moderator at Large
Brampton, Ontario, Canada
2006 Jetta TDI
The deal with the upcoming engines (Jetta) requiring 507.00 is new, although unsurprising. I think within a couple of years, the 505.01 oils will be obsolete and it will be 507.00 for all TDI's.
Long_Range
Arthur, IL , USA
Jetta Sedan GL 2004
wjdell said:
by 2010 it will be - 20% of US fuel still 500ppm
Don't know about the rest of the world. But in my little warm corner I've seen nothing but ULSDF stickers for months. I'm speculating that 20% LSD could be big fleet and military use. It's my belief most of the LSD stickers seen on pumps are owners shielding themselves from possible failure of the 15ppm spec. I'm also positive there are old rusty muddy tanks in the ground which will not pass until they are cleaned or replaced.
I'll wish all those owners good luck.
Since I don't plan on loosing my 2004 model any time before I retire it's a moot issue for me. I just have to remember to pump in D2 and NOT gas. So far I'm batting 1000.
Long_Range
Arthur, IL , USA
Jetta Sedan GL 2004
Perhaps obsolete at the dealerships.
You won't find me running an XW-30 oil in my car.
At least not until thousand of drivers run 800K miles on it. With no issues.
Call me old fashion. I like high viscosity. Other people have different expectations from their cars. I bought mine new so I wouldn't have to deal with what other people did with my car. For sure that's fickle.
I don't like the way my 505.01 shears down to almost a 30. 12.56 on my last 10K uoa. 12.5 being the cutof point.
bhtooefr
Newark, OH
None
Long_Range: In Europe, they've run quite a few collective miles on 5W30 and 0W30 oils in PD-TDIs, seeing as they're required for the flexible service system. ;) (506.01 and 507.00)
bhtooefr
Newark, OH
None
High-ash oils can poison the particulate filter, NOx catalyst (if not urea-based), or SCR system (if urea based), just like 500ppm sulfur in diesel can.
VelvetFoot
Sand Lake, NY
NB, 2000, Yellow
But VW would probably specify an oil that would be downwardly compatible with the PD's special requirements, no?
tditom
Jackson, MI
Can anyone explain why the German VW oil chart that lists uses for 505.01, 506.01 and 507 explicitly states that the V10tdi only use 506.01 (both with and without DPF)?
HopefulFred
Atlanta, GA
Golf, 2006, Indigo Blue
Tom - I think that "German VW oil chart" is for German market consumption only, where all V10 TDI's are flexible service interval equipped. Since 505.01 is not a long-life oil spec, 505.01 is no good for German V10 TDI's. As far as 507.00, I suspect that the chart predates the availability of that oil, but I don't know.
As for 507.00 oil in my '06 Golf, I like the possibility, but I want to see some evidence that it is superior to 505.01 for a 10k OCI.
tditom
Jackson, MI
The chart says that 506.01 is to be used for both V10 and R5 tdi's with and without "long life" service (equipped with flexible service sensor), as well as with or without DPF.
The chart also has 507 applications listed (all other vehicles with DPF).
dieseldorf
MA
I'm glad to see at least one person is paying attention! :D
bhtooefr
Newark, OH
None
But this isn't the German market, this is the North American market, and our toerag uses 505.01 or 507.00. (506.01 is acceptable by virtue of being 505.01 compliant.)
On that note, isn't 507.00 compliant with 506.01?
dieseldorf
MA
Yes, E, everything is dumbed down (and potentially inappropriate) for the USA market.
If 505.01 or 507.00 were acceptable for the V10, why would it not show it on the charts :confused:
FWIW, 506.01 doesn't exist in the USA from VWoA's POV ;)
tditom
Jackson, MI
bhtooefr-
Do you think the German touareg differs from the N American market in terms of lubrication design? Why?
They have had the more advanced emissions equipment (DPF) over there for awhile, yet have continued to spec 506.01 for the R5 and V10. It may have something to do with the cam drive system used in these motors (gear driven vs belt). That's my theory anyways.
507 is compliant with 506.01 in all but the V10/R5 apps, from the Euro oil literature I've seen.
bhtooefr
Newark, OH
None
Doesn't the US-spec 06-07 Touareg have a NOx trap? Is it possible that the 506.01 poisons it somehow?
dieseldorf
MA
Guys, have there been previous instances where VWoA has recommended the wrong product
tditom
Jackson, MI
here is a clue from Lubro-Moly's TopTec 4200 oil:
Operational area on LM brit site said:
Special all season oil for all gasoline and diesel engines of the Audi and Volkswagen group. LIQUI MOLY recommend this product for vehicles for which Volkswagen specifications 500 00 / 501 01 / 502 00 / 505 00 / 505 01 / 503 00 / 503 01 / 506 00 und 506 01 (Exception R5 and V10 TDI-Motoren before 6/2006) are required.
Car manufacturer´s approval: ACEA A3/B4, VW 504 00/507 00
So perhaps bhtooefr is onto something that resulted in a change to these oil requirements sometime in the last year or so.
In either case, I would not use a 505.01 product in the V10/R5. And I would suggest that owners with pre-6/06 V10/R5 vehicles use 506.01.
