Another Disbenefit to NOx Emission Reductions Discovered
wxman
East TN, USA
Other Diesel
As has been discussed on this board many times, it has been known for decades that large reductions in NOx emissions in certain locations can lead to an increase in ambient ozone levels ("weekend effect"). This mostly occurs in large metropolitan areas.
A paper just published in the Proceedings of the National Academy of Sciences shows that reductions in ambient NOx levels can lead to increases in formation of secondary particulate matter (secondary organic aerosols - SOA).
Abstract:
On-road gasoline vehicles are a major source of secondary organic aerosol (SOA) in urban areas. We investigated SOA formation by oxidizing dilute, ambient-level exhaust concentrations from a fleet of on-road gasoline vehicles in a smog chamber. We measured less SOA formation from newer vehicles meeting more stringent emissions standards. This suggests that the natural replacement of older vehicles with newer ones that meet more stringent emissions standards should reduce SOA levels in urban environments. However, SOA production depends on both precursor concentrations (emissions) and atmospheric chemistry (SOA yields). We found a strongly nonlinear relationship between SOA formation and the ratio of nonmethane organic gas to oxides of nitrogen (NOx) (NMOG:NOx), which affects the fate of peroxy radicals. For example, changing the NMOG:NOx from 4 to 10 ppbC/ppbNOx increased the SOA yield from dilute gasoline vehicle exhaust by a factor of 8. We investigated the implications of this relationship for the Los Angeles area. Although organic gas emissions from gasoline vehicles in Los Angeles are expected to fall by almost 80% over the next two decades, we predict no reduction in SOA production from these emissions due to the effects of rising NMOG:NOx on SOA yields. This highlights the importance of integrated emission control policies for NOx and organic gases.
http://www.pnas.org/content/early/2017/06/13/1620911114.abstract
Thus regulators need to evaluate their approach to NOx and VOC emission controls carefully.
wxman
East TN, USA
Other Diesel
Reducing NOx emissions relatively more than VOC (NMOG) emissions will produce more ambient PM.
wxman
East TN, USA
Other Diesel
At the very least, regulators should be/should have been focusing on VOC emission reductions more than NOx emission reductions instead of the other way around.
ZippyNH
Southern NH
2015 JETTA TDI SE
Do things like regulate motorcycles that pump out more emissions in a few weekends a year than a car does in years?
Naww... makes too much sense.
firehawk618
Marysville, WA
2011 Golf TDI, 2dr, M6, Stock
What about killing a diesels economy for the sake of reduced tail pipe emissions?
At what point does the higher consumption of fuel cancel out said tail pipe emissions savings?
2015vwgolfdiesel
Oklahoma
2015 VW Golf S DSG Silver
It's out of your (and my) hands.
The power brokers are the ones we have voted for. :eek::rolleyes::p:cool:
Kevinski4
Nebraska
'00 ALH Jetta GLS
The other NOX disbenefit has caused us to CRUSH THREE HUNDRED THOUSAND FUEL EFFICIENT CARS.
BleachedBora
Gresham, Oregon
'81 DMC-12, '15 GL350 CDI 275 hp/448 tq - '81 Caddy ALH, '05 E320 CDI 250hp/450 tq
Final tally according to my sources will probably be 400,000. If a fix isn't approved...
2015vwgolfdiesel
Oklahoma
That is the dark side of it. Of the (approx) 500,000 units to start with we will have only about 100K left remaining.
Of those 100K units they are subject to attrition. Mileage, wear and tear, wrecks ... well you get the idea.
Then it all boils down to fewer and fewer remaining VW 2L units.
Fixed GEN 3 units also have a 162,000 warranty.
They won't go up in price, but (me thinks) they will depreciate slowly:D
Well it seems there is no secret that the regulations are not in favor of fuel efficiency. At all. But neither is the bulk of the buying public's purchase choices.
It is like the mouse I found in my uncle's cabin that chewed a hole into the plastic lid of a jar of pork rinds. The jar was full...when he got in. But he ate himself down so far, he could not climb out. So he was stuck. But with plenty of food. He continued to eat, until he died in a pile of his own poo at the bottom of the jar.
We KNOW what we SHOULD do, we just won't do it. And some of us that at least try to make wis(er) decisions get those choices taken away. No, you cannot buy your 50 MPG Volkswagen, but rest assured you can buy as many 15 MPG Chevy Silverados as you like. One rolls off the assembly line about every 45 seconds. :rolleyes:
2015vwgolfdiesel
Oklahoma
.... snip....
The quick and the dead
for Swift buyers there is still a limited few *new* TDIs out there.
But also there are used units to be had ... as they come back on the after market
n1das
Nashua, NH, USA
What wxman said. :cool:
I will gladly take high NOx from an emissions cheating CR TDI any day while having significantly LOWER emissions compared to the gassers in all other emissions categories.
I know I'm preachin' to the choir here. :)
2015vwgolfdiesel
Oklahoma
They are not a joke. They are they are the law of the land (unfortunately).
Yes,
They (CARB EPA etc.) are the law
First I was ticked off, but now all is well.
Thanks to *them*, the CAS lawyers, and the people who discovered the cheating
wxman
East TN, USA
Other Diesel
Yes,
Your 2015 TDI probably doesn't actually have NOx emissions that are much, if any, above the regulatory limit (FTP), according to comprehensive testing by CARB ("special driving cycles and conditions that may reasonably be expected to be encountered in normal operation and use"):
The "emissions after repair" of 2015 TDIs puts the NOx emissions near SULEV levels (0.02 g/mi) according to the graphic.
So diesels are capable of achieving very low NOx emissions. The question is how much does that really help from an air quality perspective?
2015vwgolfdiesel
Oklahoma
Not much
All I can say is that I am a happy camper
I get to keep my car (with the fix) and get paid well to do it. :)
Oilerlord
Edmonton, Canada
2012 JSW TDI w/DSG. 700 Mile Club. 2008 BMW X3 "Beatrice", 2004 BMW 330Xi, 2014 Mercedes B-Class Electric
meerschm
Fairfax county VA
seems like VW met the deadline for submission of a fix for gen one cars, which is still in testing.
the decision to fix or dispose is still pending.
hey_allen
Tacoma, WA
2000 Jetta TDI
I've drooled a few times over the lot about 3/4 mile from my home, full of various late model TDIs.
I don't own anything newer than my Mk4, but would definitely be willing to do my part to help with fuel economy and drive one of them, given the right prices!
Marcb
Centralia, Washington USA
2001 Jetta TDI
There is a local salvage yard near me in Olympia that has been commissioned by VW to crush the CR cars. All they can remove are the tires and wheels. Everything, and I mean everything, is crushed flat. What a sad waste!
mikew85120
Arizona
2014 Passat SE TDI
all fine and well
The EPA mandated fix has been done on my 2014 Passat. I was just on a trip and noticed that the semi trucks had stickers stating 'certified clean idle'. My Passat did that before the fix, where is my sticker?
piotrsko
Reno Nv
2013 Golf, 2000 F-250 (7.3)
you're not a commercial vehicle and so don't get one. Those are there for out of state trucks being allowed into CA as emissions compliant.
tikal
Southeast Texas
Thanks Brian for putting a fair balanced statement on this topic.
"It takes two to tango": The EPA/CARB make it the bar higher and higher for light duty diesel vehicles (as compared to gasoline vehicle counterparts) and the general American consumer is more than happy to keep buying larger and larger gasoline vehicles (SUVs/trucks) driven primarily as single occupant daily drivers for non-commercial use (not much cargo/load on the average).
And if the price of fuel cost is still relatively low and the CAFE standards are relaxed, even less light duty diesel passenger cars (non-luxury) will be available!
2015vwgolfdiesel
Oklahoma
.....snip....
.....and the general American consumer is more than happy to keep buying larger and larger gasoline vehicles (SUVs/trucks) driven primarily as single occupant daily drivers for non-commercial use (not much cargo/load on the average).....snip....
During my working days (retired now) I owned a 3/4 ton van to acquire, and transport my wares -- ladies, children's clothing
In a typical year we would handle about 40,000 garments In a one year time frame the unit was hauling goods about 50-60 days.
We both (wife and I) used it a a daily driver, as needed. We had 3 Accords, and one Civic at that time. She choose to use the van as a driver, more than me.
To save on fuel, we could not own a work van, and 2 new-ish gas sippers.
Rembrant
Canada's Ocean Playground
2013 Golf TDI DSG
Man, that drives me crazy. I can look past a lot of things in this world, but the amount of people driving around alone, hauling nothing, in full size V8 pickups day in and day out just drives me nuts.
Blue_Hen_TDI
Slower, DE
owned: 96 B4V, 06 Golf, 12 NMS, 15 GSW
And most of them where I live are now installing bright ass led light bars on their jacked up hickmobiles right smack in the center of their front bumpers at my eye level.
Yee haw.
I just constant high beam them on general principle.
Agreed, it is pretty appalling. And I know a LOT of people like that. Heck, I work with people like that.
My F150 stays at home 95% of the time, and is only used when I need a truck. And it gets by just fine with its base 145hp 6cyl. And now that I have the Sprinter, that need is probably reduced even more. But given its 21 years old, is in near perfect shape (was stored in a garage never moved from 2000 to 2015), I am keeping just because of its semi-classic status, and I like it.
But for everyday driving, my 50+ MPG NOx-spewing evil Volkswagen will do just fine.
