Another dealer oil spec check
JoshWagen
Kansas City
Current: '15 GSW, '11 A3 Former: '13 JSW, 99.5 Jetta
Hey all - I’ve got another VW dealer oil spec I’d like to verify. Listed as G-030-01B-S0 on the dealer invoice. Internet search is no use. Anyone confirm this is 507 spec? Thanks!
JDSwan87
Black Swamp Thing
Michigan near Toledo
2001 Jetta TDI, 5 speed Lagoon Blue Metallic(sold); 2005 Jetta TDI Wagon auto
Why not ask them for a print out of the oil they used? Or maybe a pic from the side of the drum that should have the specs listed?
DivineChaos
Minnesota
mk6 jetta sportwagen tdi
Well if you can't find anything related to it.. how can we? It's new maybe. Or maybe that's the bulk lot code only available to dealers? So call and ask the parts counter.
Abacus
That helpful B4 guy
Only the B4V left
Because there are many in this group that either work in the field and have extra knowledge or are better at finding answers. It happens a lot here and I am always amazed and appreciative of the knowledge on this board.
DivineChaos
Minnesota
All I'm finding is it's cheap.... If it's that new.. the other guys would have to call vw as well.
TurboABA
Kitchener, ON
RIP-2010 Jetta 6spd 2014 Touareg Execline
I can only assume that you're having the oil changed at the dealer. If so, don't sweat it and keep your receipt in case of future issues.
If you are buying the stuff, read the bottle\container they give you when you ask for that part #.
There can be different part numbers applied to different oils depending on the container size, or bulk, or a local source beyond the normal VAG parts network. Not all dealers are the same.
