I inherited a Jetta 2003 TDI manual transmission wagon with 250K miles that had a new timing belt installed but was mistimed according to VCDS. I drove it home about 50 miles. Using this forum I learned how to pull the timing camshaft and reposition the timing belt and injector pump and was able to get the timing corrected and verified with VCDS. It ran fine for about an hour while I warmed it up and kept on adjusting the timing. I did clean the camshaft and gear and then torqued to 40 ft/lbs.
Unfortunately I also decided to change the oil and I think I overfilled by it by at least a quart. When I drove it out of the garage the engine made a "clunk" and died.
I pushed it back into the garage and found that I couldn't turn the engine over by hand. The timing belt had slipped and was now hitting the pistons.
I understand that most of the recommendations for a timing belt slip is to rework the head and lifters, but I thought I'd try to get this running so I can move it into a better location before working on it.
I first drained about a quart of oil.
I removed the camshaft gear and retimed the engine so I could crank the engine to do a compression check.
Here's the psi I got:
#1 420
#2 470
#3 420
#4 405
In order to get the compression through the glow plugs I had to remove the lines to the fuel injectors. So I knew I would need to reprime.
I've now retimed with a new timing belt kit and primed the fuel filter, injector pump and injectors, but I can't get it to start... when I turn the key the
glow plug lite turns on for a few seconds, and then turns off (I'm in California where it's been above 40 degrees), the car cranks fine but it doesn't start.
Here's what I've tried....
My only clues as to what could be wrong are:
When I spray starting fluid in the intake, the engine tries to start but then dies. I assume that's shows a lack of fuel ?
I ask VCDS to show the ecm voltage and it reports it's "10.6" volts. Is that normal ?
My wife has been patiently waiting for me to get this car running so she can have her parking spot back.
So I'd appreciate any help with getting this engine started....my questions are:
#1 420
#2 470
#3 420
#4 405
- I've checked the battery voltage and it's at 13.27 volts
- I've reprimed the fuel system a zillion times using both Whitedogs and MoGolf's procedures.
- I see no fuel leaking around the fuel filter lines.
- I've pulled a pint of fuel through the return line to the fuel filter by applying a vacuum to the return line.
- I used a dial gage and a small stick in the #1 glow plug to verify I was at top-dead-center.
- I've checked several times that I'm in the right hole for the injection pump pin.
- I've loosened the three injector pump bots and slightly adjusted to both advance and retard the timing from the "pinned" position.
- I've checked the EGR valve is in the right position
- No diagnostics codes from VCDS.
- Using VCDS I see that the engine RPM is about 250 RPM's when I crank the engine.
- When I turn the key the voltage applied to the fuel shutoff value is "on" for about 1 to 2 seconds. then is 0 volts.
- I've checked and applied Whitedogs "car won't start troubleshooting" tips that might apply.
- I've tested relay 109 and that seems to be working fine.
- is the compression good enough for the engine to start ?
- is the ecm voltage reported by VCDS too low ?
- should the voltage to the fuel shutoff valve be on longer than 2 seconds ?
- what could I have damaged so much that even though I can turn the engine over it still won't start ?
- could a stuck/damaged valve give that compression and prevent it from starting ?
- Should I just move on to rebuilding the head ?
- what other diagnostics can I do to check that I have the basics of air, fuel, compression ?
