Another Coolant Temperature Problem
Stix37867
Tampa, FL
2014 Passat TDI SEL Premium
I've been really trying to fight through the hurdles of TDI ownership but I am nearing my breaking point. And just to clarify, I am an engineer that designs a high performance marine diesel engine for the NAVY so I am well aware of engine fundamentals and design. That being said, I am at a loss with where to go next with troubleshooting.
In my 3 years of ownership, I've accumulated 62,000 miles (many of which are highway) for a total of 108,000 miles. After reading up on this vehicle, I bought a OBD bluetooth scan tool and use it most days to monitor engine vitals. Over the past 3 years, the car traditionally ran in the range of 208-212°F and at 212-217°F during regens read directly from the scan tool and not the gauge cluster.
Fast forward to 6 months ago, I noticed engine temperature started running progressively hotter at 214-221°F and 219-225°F+ during regens. I did a heater core change and flushed the coolant as my heater core needed to be replaced anyways (low heat output but since in south Florida, don't really need heat). This didn't really help at all with engine temperature.
Recently I noticed I had to add coolant every week and it appeared to be coming from the oil cooler. I also tested multiple times while driving on the highway and operating at "higher" temperatures if I increased RPM during cruising from 2200 rpm to ~3200 rpm (downshift from 6th to 4th), engine temperature would fall fairly quickly by around 7-10°F. I also read the temperature while performing this at the second engine coolant temperature sensor and it would go from ~110°F up to ~140°F. After all that, I decided that my thermostat was likely getting stuck or operating inconsistently as there were times engine temperature would operate at 208-212°F and the secondary temperature sensor would show ~140°.
I just finished replacing both this past weekend. What a PITA that job was! This is definitely a terrible design. Not only is servicing ridiculously difficult, but the sheer amount of coolant lines is insane. So many places for failure when more traditional implementations would have been sufficient.
Once I did get the coolant thermostat assembly and the oil cooler out, I inspected both. The oil cooler had the common o-ring failure at the coolant port. That, I was confident, was my coolant leak. I also found lots of the typical orange particulates in the coolant port on the block and clean out as much as possible. As for the coolant thermostat, disassembly shows no major indications. I did notice the rubber seat surrounding the thermostat was deformed due to years of being embedded into the plastic housing. That too seams like a deficient design as the spring is quite aggressive. After test driving the car with the new coolant thermostat housing, new oil cooler, and a fresh fill of coolant, I had high hopes but was ultimately let down once again.
Now, the symptoms are getting worse. When I begin my morning drive on the interstate, the coolant temperature goes to ~217°F with aux coolant temperature sensor at ~105°F. After 20 minutes, something happens and engine coolant fall abruply to ~203°F and the aux coolant temperature sensor rises to ~160°F. This tells me that the thermostat opened more allowing more water to flow through the radiator, rather than bypass, and thereby raising the temperature at the aux coolant sensor and lowering the engine temperature. However, it gets better. Another 20 minutes goes by and the engine temperature begins to slowly climb again as does the aux temperature sensor reading. Eventually before leaving the interstate, engine temperature climbed to ~223°F and ~190°F. As I sat through various lights, the engine temperature fell to a wide range of values from 203-217°F.
I'm really at a loss as to what is going on with the engine. I'm sure the radiator is not is great condition based on the amount of debris that was in the coolant but I've never soon a radiator behave as such. I've also never known a water pump to fail in such a way that it operationally, it is inconsistent at static conditions. I've also never head of water pumps failing in CKRA outside of an occasional seal going bad. When replacing the thermostat assembly, I could obviously see the impellers and nothing looked amiss. Lastly, some technicians in our shop mentioned a possible blown head gasket. It is possible except that while I have been seeing elevated temperature for some time, I have not been eating coolant until recently with the oil cooler leaking. I could confirm this with a combustion gas detector but don't expect to see anything from this.
Any ideas would be appreciated. I can also capture any data if needed from the obd tool. I did plan to delete soon as I am approaching the 120,000 DPF likely end-of-life and perform the timing belt change while I'm working on it. However if I can't get this problem sorted, I definitely don't want to put more money into something that I will ultimately move on from. I also hate just throwing parts at it and was hoping to hear from others successful repairs before throwing another $2,000 into a sinking ship.
AverageAndy
Phoenix, AZ
2013 Passat TDI SEL, 2013 Jetta TDI 6MT
Interested to see what you find. I have been following my temps since getting VCDS for an injector replacement about 10k miles ago and find that my coolant temps are usually 220-225F under load, 225-230F during a regen. I am not losing coolant, but keeping an eye on it. I have noticed that sometimes the temp will seem to fall quickly to ~215F. Also, sometimes it will climb above 225F outside of an active regen, causing the needle to rise off 190F on the dash. This will only happen for a few miles and then go back down.
I was worried about the oil cooler failing, but a recent oil analysis did not show any amount of coolant. Of course it could leak outside, but again I have not noticed any loss. I have not checked the aux temp sensor -is that a measuring value in VCDS?
I too had someone suggest the radiator being the issue, but it does feel like something will be not working optimally, then suddenly start working again. Does the CKRA have an electric auxiliary water pump? Maybe that is starting to fail, just not enough to trigger a code?
Dalon
Ohio
2006 MKV Jetta TDI 1.9L - 210k 2013 Passat TDI - 27k
Interested to see what you find. I’m on a GTB turbo with a tubular manifold and have the EGR system completely out of the loop, exhaust gases don’t even flow through the head anymore. My oil doesn’t exceed 200-201°F while I’m cruising at 70mph in 90° weather. I have PolarFIS but haven’t hooked it up yet since I’m in the process of refining the tune, once I do I can report back with my coolant temps.
Stix37867
Tampa, FL
After researching the oil cooler problem, I found that most failures are with the coolant jacket seal. The oil has a separate seal which should keep out any coolant when it fails unless the oil seal fails too. This is why most see coolant leaks externally.
The CKRA does not have an aux water pump except for the small electric pump for the charge air cooler. I am unsure what the design intent on the two engine coolant temperature sensors was. The service manual only labels them as Engine Coolant Temperature Sensor -G62- & Engine Coolant Temperature Sensor on Radiator Outlet -G83-. On my OBDLink scan tool, they are simply listed in the SAE PID library and engine coolant temperature 1 & 2. I do not own a VCDS yet as my Scantool has got me by thus far. Quick research looks like the Engine Coolant Temperature Sensor on Radiator Outlet -G83- on VCDS is in the Advanced Sensors list under the same name.
AverageAndy
Phoenix, AZ
Thank for the info on the radiator outlet temperature sensor. I suppose the reason to have that sensor is to know how well the radiator is working, as the outlet temp from radiator should be the lowest temp for the coolant while engine is being operated, correct?
My car is stock and regens are every 275 miles. I have heard those running a tune only (such as Kerma) see regens every 450-500 miles, due to dynamic EGR. I would guess that shutting off the EGR once at operating temps would possibly lead to lower engine temps. This is one reason I am considering a tune at 150k+ miles. The other is that it would delay a new DPF by about a year or more, based on my current usage.
Stix37867
Tampa, FL
I don't believe oil temps are reported over the OBD port but I will confirm later today.
There is no doubt that deleting or adding dynamic EGR would reduce engine temps. My concern is that if the engine was operating at 212°F for 40k+ miles and then started to slowly run hotter, there is obviously something else wrong going on. Deleting will cool the engine down but not address the failing part(s) till it's too late. Rather get the car running back to normal before deleting knowing then that it should be good for a considerable time.
AverageAndy
Phoenix, AZ
Yes, there is an oil temperature -that is one I monitor in VCDS.
I can't delete in my county, so it would be a dynamic tune only. I agree it won't address a failing part, assuming one is failing. There are lots of places the coolant flow could be disrupted, and maybe one of these is the issue given the way the coolant can breakdown? I have considered doing another coolant flush or even a radiator clean/flush to see if that improves flow and cooling ability.
06bluebeetletdi
Middlesex, NC
I have a 14 passat, it used to run 207-215 for coolant temperature all the time, during regen in the summer, it could hit 225 (air temperature 95+). After replacing the oil filter housing and thermostat in october at 121000 miles, it now runs 195-202, during regen last week at 95*, it went up to 206, it was at 195 while cruising on the highway at 70 mph at 95*. I have 131500 miles now. It doesn’t run the fans when i turn the car off, it used to do it all the time if the air temperature was over 72*. I find it interesting that yours didn’t change in coolant temperature at all, i had to take mine apart twice as the first thermostat was stuck open.
06bluebeetletdi
Middlesex, NC
Are both fans working? I’ve had to replace one on the passat (broken blade) and my 13 beetle tdi (stopped working completely) in the last year.
Dalon
Ohio
Right, I don’t know if it is, I have a gauge for oil temp and pressure.
AverageAndy
Phoenix, AZ
Update...so both my fans are working (at least on lower setting when I pulled in garage).
I followed my "Coolant temperature" and "Coolant temperature at radiator outlet actual" values on my commute home. The highest the radiator outlet temp got was 160F, but usually was around 150F. My coolant temps varied from 210-226F once car was warm. Interestingly, it seemed that when coolant temp was closer to 210F, the radiator temp would be around 160F. When the coolant temps would rise to 226F, the radiator outlet temps would lower to 150F. I was running the A/C at this time and had both highway speeds of 80+mph and surface streets speeds of 50mph.
Funny, there is also a "Coolant temperature at radiator outlet specified value" which read a constant 203F from start to finish, even when engine cold.
Check the coolant vent tube assembly for blockage. Very common problem on the CKRA.
Start at the coolant bottle and work backwards ... there may be a little restrictor in the hose, too.
Stix37867
Tampa, FL
Ahh thank you for the advice. So the theory would be that there is air in the system causing the erratic behavior?
Stix37867
Tampa, FL
Your system appears to be acting as expected in that as engine temperature increases, the thermostat would open to allow more coolant to flow through the radiator thereby cooling engine temperature. This would cause the two coolant sensors to act inverse to each other as you stated. That fact that your system is running at 226 does seem off however that could be explained a multitude of components. Oil cooler could be plugged with debris reducing its cooling efficiency and oil running hotter. Coolant thermostat could be seeing outside of normal movement due to thermal fatigue (seals on thermostat also could no longer be blocking coolant flow from recirculating). Radiator may be less than efficient due to debris causing more backpressure to system and forcing more coolant through the recirculation system. Overall however, the system is functioning as it should but just at a higher temperature than intended.
As for the "Coolant temperature at radiator outlet specified value", I am unsure of the purpose of this. Possibly fault detection???
The vent hose assembly is to allow the superheated coolant to get out of the high hot spots. Sometimes they are called steam vents. If the coolant cannot purge the air from these places, then it will superheat into steam, creating air pockets, and then you can poor/no flow, because gas can compress and liquid cannot. So it cannot flow. Think of it as a vapor lock of the cooling system.
The CKRA (and worse, by far, the CVCA/CRUA) engines have extremely complicated cooling systems. Part of it is due to the fact that there are in effect three cooling systems running congruently; the EGR cooling, the charge air cooling, and finally the engine itself. Then if your car has a pedal deficiency, it has that cooling system thrown in as well.
The EGR cooling is in the same circuit as the cabin heater, which was how TDIs always were BUT the older ones never ran such stupid high EGR duty cycles and they didn't have DPFs so there was never any supernova levels of EGTs let alone the constant trying to keep the engine at just a stone's throw away from overheating under NORMAL conditions (this is common, all cars' engines are like this now).
And I also have my own theory that the CKRA is especially awful due to how the standard (now known as high pressure) EGR system, which has no cooler but instead just dumps right straight back into the cylinder head itself. Great for rapid warmups, not so great when the EGTs are thrice the temp necessary to melt lead.
Stix37867
Tampa, FL
That makes sense to why temperatures would cycle in longer intervals. The pockets would slowly accumulate gas/steam until finally big enough to the burp allowing water to temporarily flow again until the steam/gas would reaccumulate. I will remove all the small vent lines and check for restrictions and blockages.
I did notice how overly complicated the coolant system is when services the oil cooler and thermostat. I can't imagine the engineering team that looked at the end product and gave it approval. I know deleting will somewhat simplify the coolant but it really needs much more. If I can get this problem solved, I am just going to order everything to delete it, change the timing belt/water pump, and hope that she will be good for a while. Without the excessive heat build up thermally stressing the engine/components, it seems that the engine is solid and should last.
When I had the EGR off, I noticed it had lots of build up around the valve. I took a look into the intake manifold and that same build up was layerd well inside. Besides clogging the intake track, you could tell that when it got wet, was running down into the charge air cooler clogging that, and also could easy see it breaking bits free and into the intake valves. Just a recipe for disaster.
06bluebeetletdi
Middlesex, NC
I agree with you on the coolant system, i had no idea how much was involved with it until i had to replace the oil filter housing. The intercooler hoses and all the clamps are a special kind of crazy, i was quite proud of myself that i reused all the vw clamps except one small one by the oil filter housing.
x1800MODMY360x
AZ, USA
2013 Passat TDI SEL
It's stupid how hot the EGT get with the high side EGR when the engine is cold. Since deleted it, the car runs cooler and since I'm in a hot state. I only notice a 1-2 Minute longer warm up before I had it installed.
Also changing my oil filter with that stupid pipe gone, I make a lot less of a mess with it gone.
Stix37867
Tampa, FL
Well checked most of the small vent hose assembly for clogs and even completely removed the check valve in one of them. Coolant temperature still heavily fluctuates during extended highway drives. Doesn't overheat, yet, but will keep an eye on it to see if it improves any. Around town, the coolant temperature operates great at 201-212°F for the entire duration. Only when I am on the highway does it fluctuate from 205°F for 15 minutes to 219°F for 15 minutes and then back.
Thinking I'm just going to order everything for the delete and timing belt kit w/ water pump. Since I'll have all the coolant drained again, I'll back flush the radiator, replace the entire vent hose assembly, and sacrifice a goat in hopes for no more issues.
I think if you did the same observation during the same circumstances on the same engines you'll find that isn't abnormal. I don't have a CKRA here at the moment, or I'd spend a lunch break recording some CTS values for you to at least give you one more data set.
Stix37867
Tampa, FL
I appreciate the offer, as I do love data, but I'd probably only get more frustrated. Maybe I'll find something when I do the water pump and delete. I hate not having that warm, fuzzy feeling that the problem is solved!
Well, if the "problem" is just a poor design predicated on unobtainable within reason specifications, then not much you can do aside from deleting things. The CKRA seems to have been a one-off stop-gap experimental engine, stuck between the early CRs and the later CRs, and differing enough between the two as to not share a whole lot of parts with either. A three-year-only one-model-only freak of engineering, and not really in a good way.
Dalon
Ohio
I think if (when) my heater core comes becomes an issue, I'm just going to loop the coolant hoses together and delete the heater core out of the loop...would also be nice to find a company that can scan and remake the oil filter housing out of aluminum. Those two things would get rid of the majority of issues plaguing the cooling system.
watatrp
South Bend, IN
04 Jetta tdi (gone) 2013 Passat SEL TDI
Well I guess if you lived somewhere that you could just not have any heater, you could do that. :p
Or you could do what the old beetle owners did and plug in a supplemental heater and keep an ice scraper to scrape the frost off the inside of the windshield.
Dalon
Ohio
haha my Passat is only driven in warm weather, the brm is the one that sees the elements 😅
Yeah, well I would still need the heat to regulate the A/C as my cars' would get TOO cold without the heat mix.
Dalon
Ohio
Oh, deleting the heater core would make the A/C run improperly? Or just colder?
Your A/C's temp is regulated by mixing in air pushed over the heater core. The A/C has one "setting", and that is ON and COLD. That's how automotive A/C works. The system will always try and get the evaporator core temp down to just above freezing with some margin so it doesn't actually freeze the condensate into a block of ice. So let's say 37F, which means the duct temp might be able to get as cold as 45F or so. You can change the BLOWER speed, but you cannot change the evap core temp. If the A/C is on, it's on.
So when it gets too cold in the cabin, you move the temp knob off of cold and that forces some of that super-cooled air (ALL the air in the HVAC blows over the evaporator core) to then blow across the heater core (which is ALWAYS hot, because it ALWAYS has hot coolant flowing through it) to balance out the temp.
So if you have no hot coolant flowing through the heater core, then you'll always have full cold all the time the A/C is on. Now on a 100F+ day, you may actually want that, especially for shorter trips. But on a milder day, or night (with no sun load), or a longer trip where you've had plenty of time to cool the cabin down, it may actually become TOO cold in the car. I know my cars are like that, and I like cold, I hate hot weather. But after 30 minutes in my Golf, even on a 100F day, I have to mix a little warm air in so I don't get an ice cream headache. My F150, which is a regular cab truck, so its HVAC is designed to handle a cabin size two or three times the size (Supercabs, Crewcabs, Bronco) will give an ice cream headache inside of 10 minutes, LOL.
Of course, you could also open a window... or turn the A/C off.
