pdq import repair
A couple of years ago I bought a wrecked 09 Jetta common rail for the engine mainly. I figured someone would need one soon enough and I got the car cheap enough to make a profit on it. Well apparently they are pretty reliable and I have been saying that someone better buy it soon or I would have to find something to put it in.
I first needed to get it running standalone for a swap project to materialize so I sorted through the wiring harness and painstakingly hooked everything to the ECU and engine. I had planned to do a DPF delete among other things to simplify it as much as I could. I found I had to wire in the CAN gateway to communicate with the ECU through the OBDII connector. Since I was/am still in the experimental stage and have not modified an ECU yet I also wired the cluster and key reader coil to the CAN in order to run the engine. Once I had it running I then needed a test car. I have a VW mechanic friend who has a cut down 69 Beetle that has had many many different engines in it and currently had an ALH running a mechanical pump installed so we figured it would be a good test vehicle as it was already converted to water cooled diesel.
We have it in and running now and are working out the details as we go. We figured it would be a good driveable test stand. I have slowly been working out the wiring to get rid of codes that I can. It is still complaining about some things it has noticed not there, but I have the codes dealt with for the components I intend to keep, so now it is ECU lobotomizing time next.
It looks fairly simple from the back view which is what most people see on the road. It prompts many questions when stopped and parked. He takes the car to many local car meets and many people walk around it more than one lap shaking their heads, and that was with the ALH. Anyone that knows will always ask many questions. Those that don't, but think they do often ask silly questions like "Is that a Ford engine?" On the ALH he went as far as to put a VW turbo diesel sticker on the valve cover because he got tired of telling people it was not a Ford. We are thinking a sticker or plaque on the engine cover that says "Violator" might be appropriate, or maybe "clean diesel"
It is a fairly small sized package when you get rid of the rest of the car. I improvised on the throttle for now, it would not be too hard to mount the pedal in the car I just need to extend the wires some to do it and the engine may not stay in this vehicle after all the bugs get worked out. Once tested and running as a standalone package it may find another vehicle. some considered so far have been 1st Gen 4Runner, Vanagon of course, Corrado maybe. I measured up a Miata we had in the other day and it looks like there is room enough in there too. I think that would be a fun car but I bet it is more of a project than I want.
_
I used the underhood fuse panel, the CAN gateway and the cluster so far. There has been some discussion that I may need a speed signal to get out of limp mode so I have retained the ABS controller and have experimentally hooked it to the CAN and talked to it, just in case I need to fab up a speed signal. I have experimented on my daily driver, a 09 Jetta and found that the speedo signal is generated by both front wheel sensors and if you unhook one it will still work, and with the ABS controller unplugged it still has full power so I am hoping to not need to generate a speed signal to get it out of limp mode.. The cluster is mostly CAN controlled and functions well. The display and tach and temp gauge and idiot lights all function. I have been able to shut off most of the warnings but coolant level and traction control. If i were to want to use the cluster in a build or swap it would be pretty handy as there is not that many wires that go to it to make it function. I would have to incorporate the ABS controller on the CAN and figure out a speed signal to use the speedo. The fuel gauge reads from a separate sensor similar to any other car, not on the CAN. I bet the LEDs for the warnings not able to shut off could be lifted off the circuit board, as well as the warning buzzer. The oil pressure switch was sheared off in the original wreck and I haven't replaced it yet, but the warnings come up on the cluster so I assume it is CAN too. Pretty amazing how functional the cluster is considering there are only 5 small wires total hooked to it at this point.
Another picture since any thread needs lots of them. As you can see we have simplified the exhaust somewhat. This shot was taken early on in the project before I added the MAF and added height to the air filter. I am hoping that the MAF can be eliminated with the elimination of EGR as I believe it is mainly used for control of that. At least that is how it went on my mk4 PD. I like the looks with the shorter filter, and I want to make it as simple as possible. Time will tell and theories will get proven or discarded as the project progresses. If anyone has any insights or suggestions or discoveries from their own project, I am all ears. likewise I will share what little i know.
We have driven it on the road, and even in limp mode where it will not rev beyond 3000 rpm, it runs much stronger than the last ALH. Even short shifting and gassing it we get clutch slippage in 3rd and 4th gears. That was never a problem with the last engine. The owner of the Beetle also claims it is way smoother.
_
