Interesting read on the replacement of the cam and related parts.
My 2006 Jetta has 106k miles on it. I do not plan on removal of the cam cover for a look see. When the engine starts acting poorly, then I will look
You have made the choice of thousands.
I had 107,000 miles US when I pulled my valve cover. 107,200 miles more and I had little copper streaks. 107,300 miles I had copper streaks and small raw wear streaks (tiny). I parked the car got cam bearings, installed them, polished off the streaks (very light wipe not rough). I now have 142,000 miles US on the same cam. You can see my polishing marks (400 grit ?).
I just pulled the VC by Grace. 1,000 more miles and it would not have mattered (too late). I suggest as an option for others (Crosley has already made his decision)----you might consider changing the cam bearings at the first belt change (if you have no wear). May be a waste, but if youur cam fails at 120,000 miles you might wish you had.
Of course blapping used to be the sound your air-cooled VW had pulled the head stud threads out of the magnesium case. If your air-cooled missed one morning till warm; you were warned that the exhaust valve was streaching and you could have a dropped valve soon. I used to buy torn up, or worn air-cooled beetles. If they had about 50,000 miles on them I would yank the engine put in exhaust valves and wait till the block was worn and needed main bearings (low oil pressure). I never had an air-cooled drop a valve for me, but I fixed a lot that did have dropped valves. If you waited till the valve dropped you probably had:
A bent rod
A hole in the top of the case
A destroyed piston and cylinder
A head that needed welding
Sometimes a destroyed follower bore where the valve head landed and was hit by the crankshaft
Possibly some pulled head studs.
Trash to clean out of the oil system
We have really made progress. We still wait for misses and bupping to make decisions. Now bupping is the sound your TDI PD has a flat cam lobe and worn through follower.
eddif
