Gospel???
That one should grind away part of their cam bearings? That one should open their VC every "1,000 ; 2,000; 5,000 ; 10,000 miles etc."???
And take the bearing out to show people?
Cams walking? Amen, Brother
Certainly not gospel. All the shouting, chanting and hoopla! It resembles a cult. Maybe even a snake handling one. No thanks, I will pass on that kool aid.
Personally, I would much rather see scientific engineering or real failure analysis with some analysis of all factors.
At times I totally agree with you.
If VW had assigned 5 dynos, 5 engineers, and 10 workers to the PD project for two months to find a way to direct oil in the cam bearings I would not be doing any of my dance.
I did not reduce the load bearing area of the bearings. VW engineers did.
I avoid cutting in load bearing areas all that I can. The largest amount of babbitt surface area I cut is in / over the non load bearing areas that VW created. If the areas are not carrying load they are just being used as levers to either bend the bearings or cause cocking.
There is no great mystery. The bearings and oiling are the trouble spot that pushes the narrow lobes over the edge.
UOA is part of the picture. Used parts analysis is more of the rest of the picture / story. To you it seems dumb to look at wear. To an independent research facility testing oils "It is part of the job).
I am doing what VW should have done. I am a jerk from Mississippi and am well aware of that. If it seems a little hyper it is.
Might I ask what this was ?
" Gospel???
Cams walking?
Amen, Brother
What are you asking for: Ignorance? No testing? Blind speculation? Waiting on VW to open up the dyno room hire engineers to fix the TDI PD problems (don't hold your breath).
I hear your chant. I hear your hoopla. I choose not to drink your kool aid of death of the PD.
I promote life of the PD. Everyone who presses on and finds something that works I cheer.
eddif
