First the oil slot coverageSo a different opening and closing ramp such as with a BEW cam doesn't really address the root problem, it might just buy you a little more time because the ramp up/down loads are perhaps gentler causing less cam to lobe wear but not less bearing wear.
Your implication seems to be that lobe/follower wear is a result of reduced oiling caused by bearing wear.
Could you expand on:
Lack of oiling to the lobes/lifters could be supplemented easily enough, but I don't quite understand the dynamics of the bearing oiling.......................
- Cam bearing oil slot coverage (and thus follower oiling) takes place at different mileages for different people.
- The cam bearings do not have enough support under them and experience cocking from cantilever forces (both balanced and un-balanced)
- (BRM)Cam position is worse. The belt end climbs a lot and very early copper release can happen. Cam position can possibly contribute to failures.
The inner circle is of course the camshaft bearing journal. The clearance is exaggerated for it is actually only about .003".
Then looking at a photo that shows the bottom row (beginning position of the cam wear at low mileages). (BEW) Center row at 105,000 miles US. The top row is the top cam bearings with 105,000 miles US.
The bottom row is the beginning position. Plenty of room for oil to exit the oil slot and get to the bearing wear spot, and the followers.
How long it takes for the cam to move to cover the oil slots (shown in the middle row at 105,000 miles US) depends on:
Oil
driving conditions
OCI
percent of WOT driving
etc.
This picture will show how the extra oil gets to the follower tops.
Right out of the bearing to be slung around to hit the followers. It is not a direct path but in the area. The oil goes about 35 degrees from the oil slot to the follower top and may be hitting about right (I do not know it is the correct rotation direction to do this). It does not have to go straight there but there is plenty of oil flow when everything is new.
This photo shows the head and its lack of support for the cam bearings. A wide bearing is placed over a narrow amount of metal support. Hydrodynamic oil film actuall forces the cam bearings to bend and stay permantenly deformed a tiny bit. It only takes .0001 deformation to show a wear surface pattern change. Not one thousanths but one ten thousanths.
BEW cam position. Even cam position except for cocked flywheel bearing making it look strange, but all other bearing wear patterns show cam to be in line.
BRM wear pattern showing the cam position. Cam actually starts to show it is not in line very well. IMHO it is the increased oil flow from the oil pump drive combined with the end bearings cantilever (pry bar effect that causes the poor position.
The eddif cam bearings oiling thread has all this. You got a mini version.
eddif
