Thanks for the heads up. And I agree. most people will drive a car till it's completely fubared. Would be great to save the cam and lifters.
So if I've got this correct, the cam has worn through the bearing material at the cam bearing near that lifter and the copper is the bearings backing material flaking off that cam bearing and being deposited on that lifter by that lifter's cam lobe?
so I will need the timing belt tools, the bearings and miscellaneous gaskets, of course. What do you use to press in and out the bearings? Also, I had read something about revising the oiling to the cam bearings. what is the most recent wisdom on that?
Almost forgot, used 5W30 505.01 at the 50K mile and 60K mile oil changes.
All the other oil changes have been 5W40 505.01..............
Gracious me. You did your home work pretty well. The only little difference, that can be true, is: the copper flakes being released can bounce around a lot under the valve cover, and can come from another failing bearing. It is probable that it is the lifter next to the failing bearing, but it does not have to be.
I have put in about 39 cam bearings in our car for testing and have never: loosened the tension on the timing belt, replaced the valve cover gasket, used any silicon sealer, replaced the wonderful TTY bolts (I bought some once), replaced the cam seal. I have been under the VC about 14 times now.
Are you going to do the work yourself? Have you ever rolled bearings in before? Do you have a beam, inch pound, pointer style, torque wrench (not ft lb but inch pound) (not click torque wrench but old pointer style)?
Could you listen to a jerk from Mississippi without freaking?
If you remove the cam bearings and a lot of copper release is going on, you have to pull the cam to polish the cam bearing journals.
Parking the cam with the number one, belt end cylinder, exhaust valve down right over the follower helps. You can not take all the caps off at once ETC. I used a piece of copper roof flashing material cut the width of the bearing and de burred. It is too thin but with the help of a screwdriver it can be done.
My process is not for the faint of heart. You can ruin the whole cam if you scratch the wrong thing. It takes Grace to get through it the way I approach it. If you wish to hire someone and give them $400 USD that is your choice. A fellow in Oregon said that if I could do what I was doing, I could do a lot to the PD.
The cheap way covered. The best way is to get all the tools, remove the cam from the car, polish the cam bearing journals, get the copper lightly off the cam lobe (lightly). Replace bolts, seal, bearings.
If you will send 12 bearings to me (I will probably ruin two) I will cut a set for free. Or I will even consider letting you send 6 VW bearings (only VW bearings) and you can test the new 5 ea lower (unreleased / un-posted) bearing set.
You do need to do it now. In 100 miles my cam lobes were changing. Just by Grace I got mine early enough. Your wear can only be the one copper streak or so. If you have sharp edges on the cam lobe I am afraid it is too late. You have to tell the absolute truth. If wear is there just suck it up and say so. It will fail with even a small amount of lobe wear.
I am on the 5W-40 TDT oil wagon I suppose. With wear I am on the Mobil 1 15W-50 --- TDT 5W-40 mix. Location defines mix. You are fooling with a fellow that gets some pretty healthy criticism. If I can help let me know.
PM me.
eddif
