kgirlbug2k
- Joined
- Sep 28, 2002
- Location
- Kitty Hawk, NC
When your 01M died, did you get a CEL as well?
Not only that, but the screw is on "special order"........oilhammer said:You know that pic above is funny.... because in addition to the transmission, they charged for a 'screw'. That is just funny.
Yeah, the 01M is a special screw alright And you do not get kissed with it.aja8888 said:Not only that, but the screw is on "special order"........
Yep. I call the dealer, order an 01M-300-032-GX and install it. Problem solved. Simple.Growler said:Now that Freddie has made his appearance.. (and I knew he would)
do you have any lines on good transmissions for her Brian? (of either type?)
...and it has the uber-low final drive ratio and slightly different mountings.Growler said:I might look into getting one of thses for my Eurovan. IIRC the 01P is the same tranny as the 01M, except its tilted 15 degrees and attached to the VR6...
