It is perfectly fine to split a case of twelve quarts or four gallon containers of Amsoil - the extra cost is only ten cents per quart. Many people seem interested in using the Series 3000, 5w-30 for it's cold temp properties, but feel it's expensive to use all the time. The price difference in the Series 3000 and 15w-40 synthetic is about $3.00/qt ($12.00/gallon), so splitting a four gallon case saves you about $22.00. You will see the greatest benefits from using the 5w-30 diesel oil in subfreezing temperatures, compared to using an xw-40 oil. It is really not necessary to use the Series 3000, with a pour point of -60F, when the ambient temps are 100F-150F higher. There are also some folks who simply don't feel comfortable using a 0w-30/5w-30 in warm weather, no matter how much Geoff beats on them.
Additionally, even with a PAO/Ester synthetic, it is hard to optimize an oil to perform equally well at hot and cold temp extremes. If we compare the high/low temp properties of the two aforementioned oils to a well known 5w-40 synthetic (we'll call it "D1"), you can see what I mean:
High Temp Evaporation (NOACK test)
(250C for 1 hr)
D1, 5w-40: 10.0% weight loss
Amsoil 15w-40: 6.6% weight loss
Low Temp Flow (CCS Viscosity @ -13F)
D1, 5w-40: 3200 Centipoise
Series 3000, 5w-30: 2566 Centipoise
Finally, there are any number of ways you can split these cases of quarts/gallons, to tailor this idea to your particular situation ....
TooSlick
(250C for 1 hr)
TooSlick
