Alternator not charging and battery light not on
tdisuperdave
Whitby, ON
2002 Jetta TDI
Hi, My 2002 jetta TDI is not charging (verified at battery and alternator), but battery light is off, with and without car running. Battery is good and charged. Checked all wiring including under battery box and grounds and it's OK, Grounded out the wire on the 2 wire plug for the alternator and battery light does work with ignition on. So, it's either the voltage regulator of alternator itself. Do you think I should try replacing the VR first, as it's a lot easier? Thanks
REPLY
amit9
Toronto/Scarborough
2003 Silver Jetta TDI GLS 5MT
A common failure part is the alternator pulley in these models. I had the same issue on my 2003, changed the pulley and it was resolved. Check that part.
tdisuperdave
Whitby, ON
2002 Jetta TDI
Thanks, haven't taken belt off yet, but alternator is spinning as I can see it through the holes on top of alternator, if that helps.
tdisuperdave
Whitby, ON
2002 Jetta TDI
Car did die with a dead battery, had to charge it back up. Alternator is spinning as seen through the holes on top of alternator. Just not sure if it's alternator, clutch, or voltage regulator. Do you know which part would more likely cause the battery light NOT to be on when it's not charging at all?
Bosch reman 120A alternator will fix it. I would also check the main fuse leg from the alternator to the underhood fuse link box (the one above the battery) for integrity, not melted, burnt, etc.
tdisuperdave
Whitby, ON
2002 Jetta TDI
Thanks, All fuses are OK including the large 150A and other ones too.
Where is the best place to buy a Bosch 120A alternator?
Mozambiquer
Versailles Missouri
1998 VW Jetta TDI. 1982 VW Rabbit pickup, 2001 VW Jetta TDI
Generally the Bosch alternator fails when the slip ring wears out. They're rebuildable, but I would recommend only genuine Bosch parts to rebuild.
I just rebuilt the alternator on my mk4 golf. It'll be good for another 250k miles or so.
I would not recommend getting a generic parts store one, I've seen so many of them fail prematurely.
tdisuperdave
Whitby, ON
2002 Jetta TDI
Update... Installed new VR with the alternator still in the car. It's a tight space, but doable. Turned key on and Battery light now works, started car and now have 14.4 V and it's charging correctly. New VR was $40, but not a Bosch. Thanks for your help!
Vince Waldon
Edmonton AB Canada
How were the slip rings, when you replaced the VR/brushes?
I ask because oftentimes by the time the VR/brushes go there are deep grooves worn in the slip rings and that will be the next thing to head south. :)
tdisuperdave
Whitby, ON
2002 Jetta TDI
Slip rings appeared ok, still shiny, not sure about how deep the groves are compared to new, brushes were still intact just shorter after 359K kms.
