Occams_Razor
Hello all,
My alternator has been acting up, (Alternator Workshop in the MFA and whining in the radio), even though it still puts out the correct voltage to charge the battery, etc.
I have now started getting a flashing glow plug MIL and error code in the engine module that the brake light switch is intermittent.
I replaced the brake switch for a brand new one old model one, (I bought it new from IMPEX before VW changed over to the newest versions that I swapped in last year and had never used it), and also changed the clutch switch just in case the error dealt with that instead but nothing. Code clears but comes back again after a few days.
BTW The brake lights work fine and have never failed, (unlike the time the first old switch did go bad and took out all of my brake light bulbs), and even the cruise control works perfectly code or no code.
So my question is if a faulty alternator could cause other codes due to it's flakiness?
