Lewis98
So I have am reaching out because I am 100% stumped on this one! Full story bought an 02 tdi with a blown engine with vnt17, 1019 nozzles, South Beth clutch.
Picked up a motor with 245,000 said it ran but thought the wiring in the car he pulled it out of was ****. I have 420-400 compression in each cylinder, swapped injectors out of a running car of my I know those are good, injectors pump came of a car that had run away but we got it running afterwards. Timing is 100% on. Tested all voltage and ohms to injection pump with another car I got they are relatively the same. It turns over fine at 300 rpm, and smokes like a train, white. Will run on starting fluid. Has stage 4 malone ecu. I have no idea left NEED HELP!
