ss010949
hay guys . i am able to wiggle the tube from my vacuum pump for the booster , so it must be sucking air into the head . i think it is pressurizing the inside of the engine block . when i open the oil fill cap , it sounds like a can of soda PSHHH . and have oil leaking around the fill cap . can i fix the pump tube , another pump is a couple hundred $ . hate to spend that on a new pump , when it's just a loose tube . is it just an O ring gone bad ?
