NarfBLAST
Update: Minor issue with easy fix!
Remember that bolt that conveniently sealed off the hole were the shaft of the turbine used to be?
I goofed when I put the nut and the aluminum crush washer on the inside of the housing. It did not take long for things to loosen up.
First I could hear a slight exhaust leak,
Then I could hear (what turned out to be a nut that was) rattling in the exhaust system.
Finally the exhaust leak got much louder, and I found this bolt was missing from what was left of turbo housing:
Climbing under the car I found the rattle was coming from the nut, which is sitting inside the exhaust pipe in front of the catalytic converter. The rattle only happened for a couple of days so I am guessing that was the nut working its way down all the ridges of the flex pipe. Once it was nestled comfortably in front of the catalytic converter the rattle stopped, so I don't think it did much damage there.
The crazy thing about this story is that I found the bolt, at the end of my street.
I came up with an idea to make sure this doesn't happen again. It involves mounting the bolt on the inside, skipping the crush washer, and putting the nut on the outside with a retaining pin:
This way, if the nut ever comes loose again, I will hear the exhaust leak and rattle and it could be simple to tighten it back up!
Here is the plan:
1) remove down pipe and shake the nut out
2) reinstall bolt from inside of where down pipe mounts
3) install nut and retaining clip on outside of turbo housing (easily accessible from top of engine bay)
4) reinstall down pipe
The only problem is that I have decided to park the Volkswagen for the winter:
Not to worry, this will give me more time any money to spend on my new hobby which I can work on in the comfort of my heated workshop:
I am trying to take up hiking, I don't have a dog, so I take the 1/10th scale vehicles on my hikes:
We have so many beautiful trails and waterfalls in this area, I hope to visit as many as possible.
The Volkswagen may come out again next spring if I decided I need the challenge of replacing a wheel bearing, injection pump seals, timing belt, etc, etc. Right now, changing wheel bearings on the 1/10 scale radio control models is much more fun.
Here is the plan:
