ALH thats been sitting for 5 years or so
Jsiets
Willmar MN
99 Jetta TDI and a 02 Jetta TDI
First i want to say thank you to everyone for your help getting my sons 99 Jetta up and running properly again. Now that his car is functional i can work on mine.
I have 02 Jetta 5 speed with the ALH engine it had been sitting for 5 years or so brouight a fresh battery and some oil with me to try and start it to at least drive it onto the trailer to get it home, low and behold after checking the fluids and cranking for about 30 seconds it came to life no questions asked, smoked a fair amount but figured that would happen just due to it sitting for so long and something had moved into the exhaust which came right out as the car was running.
Got it home put 5 gallons of fresh diesel in it along with some seafoam and took my son driving up and down our dirt road letting him learn to drive a 5 speed while we were getting his up and running worked flawlessly, week or two later went to move it around to the shop and it had a hard time starting, smoked like crazy, and would no get above 1200 RPM, figured the seafoam knocked some stuff loose so changed the fuel filter and bled it through the injection pump, that did not change anything, got a generic scan tool, and the codes that i pulled out of it are P0251 injection pump fuel metering control A, P0252 Injection pump fuel metering control A range/ performance, and finalla P0401 EGR flow insufficient,
planning on starting with the vacum lines and inspecting the harness for the pump as i have seen in some of the other threads on this forum, any other places i should be checking common gasket leak points, seemed to always get a tiny air bubble through the fuel line when i was bleeding the pump pulled 2 quarts of fuel through the pump with a hand vacum pump on the outlet of the pump
Sorry for the long rambling post just wanted to get the detail in there.
Thank you
Sting
I'm interested in how you make out. I bought a spare engine for my ALH a couple of years ago, thinking I might need it sooner than later. But at 715K km, the original engine shows no sign of slowing down. Good luck with getting it going.
Did you do any prep before storing it? I didn't.
Jsiets
Willmar MN
No prep was done before storing it as the previous owner drove it to a property that he owned and parked it and it did not move till the day that i bought it and loaded it on the trailer with any luck in the next week or so i will get it up and going, but beings its a back up car and work and life are crazy busy right now it might not happen right away would at least like to get it running and driving before the snow starts to fly in Minnesota
Lex4TDI4Life
NorCal
2001 Golf-Ute TDI GLS 5spd Manual
Not that this is related to the specific symptoms you are experiencing, but do you know when the last timing belt service was performed?
Jsiets
Willmar MN
Yep it has the gates sticker on the air cleaner believe it was done 20-30k miles ago
Jsiets
Willmar MN
Quick update and thanks to those that posted it is greatly appreciated. My son had bought the vag com so we hooked it up to the car and were getting a N146 quantity adjuster upper limit code. first thought was the pump but after a little research I found someone with a similar issue on a car that had been sitting a while and ended up pulling the top cover off the quantity adjuster and found it was completely coated in dried up diesel gum/varnish looking stuff sprayed it off with some brake/parts cleaner along with blowing out the lines that go to the tank and now everything is working like it should so thanks again for all your help.
Now to finish up a few other things so my son can drive this jetta while we put a timing belt into his
Gruni14
Madison
2002 Jetta
Thanks for coming back and giving the final solution. Always helpful for others. Has your son mastered the 5-spd by now?
(y)
