dlu
We have a 2002 Jetta Wagon with an ALH engine and an automatic transmission with about 270,000 miles on it. A while back the idle began to do a regular surge of about 50-100 RPM that was most pronounced on cold starts. The surge rate is about 1 Hz and it seems to be a drop in RPMs followed by an almost instant recovery. The surging starts about 5 or 10 seconds after startup, and it settles out above about 1500 RPM. Once the engine is warm it is gone or much less pronounced.
I think I see a bit of smoke at idle that wasn't there before, and driving behind the car there is some smoke at cruise too (and mileage seems down as well). Occasionally heavy acceleration (such as getting onto a freeway) will produce a truly impressive cloud of black smoke – something worthy of the smoke screen from 007's DB5. It is bad enough that I worry it could be a safety problem for following cars. But this doesn't happen every time.
Recent work on the car includes (all post onset of the surging idle problem):
I'd been thinking that the smoking problem might be due to a stuck turbo vane actuator, but testing with a MityVac I see movement start as soon as I start to pull a vacuum and I get full stroke at about 18" of Hg. As best I can tell movement is smooth.
I'd appreciate any thoughts on whether or not the two problems are related and what my next troubleshooting steps should be. I have access to VCDS.
- Replacing the EGR and cleaning the intake manifold. The EGR valve was leaking oil from the anti-shudder valve shaft and was setting codes. Carbon build up was significant but not record setting. No noticeable difference (other than fixing the codes) after doing this.
- Replacing timing belt and related parts – this was done to replace a leaking water pump). For a short while the idle problem seemed to be gone or at least significantly improved. When it returned, it seemed like it might be related to electrical loads, it seemed to happen with a significant load (AC, seat heaters, rear defroster, but not headlights). When I replaced the timing belt I also cleaned a significant (maybe a cup) of oil out of the intercooler.
- Replaced air filter. No effect.
