Nothing says "Look at me, I'm wasting fuel!" more than "rolling coal." Nevada said it all above, but I'll add just a smidgen... It is far more impressive to actually HAVE performance than to LOOK like you do. "Rolling coal" is too much fueling, not enough air. It says that one isn't optimized: or one is fueling for the racetrack (hardly with a stage 1 tune!; and, really, what the heck are you doing on the road?
Stage 2 with DLC520s is the optimal performance and fuel economy (preservation- though I'm getting killer mileage with my perf mods) setup. If you've got a manual trans you're going to have to install a better-than-stock clutch.
I can puff black smoke if I drive easy for a lot of miles and then cram the GO pedal. Most of the "black" is from carbon buildup. Meanwhile I'm still racking up killer FE and have far better performance than a stage 1 tune that's over-fueling (you can get a bit of this by dropping the IQ down, but doing so also results in a stumbling engine- a two-fer-as-dufer, as you get both a smoker and a stumbling engine!
If you insist on a trail of black smoke then perhaps this:
https://www.plowhearth.com/p/64133
Or, you can trade your TDI for an old Cummins (I've got one- performance bumped, but not for coal [can you say $2,500 for an appropriate clutch?].)
