calituner
Hey everyone. Looking for advice on my tdi swap. I contacted Malone about a code that keeps popping up on my swap. It’s for the f8 kickdown switch. Since I have a manual b4 Passat pedal assembly it doesn’t have a kick down since it’s a manual pedal assembly. So it was suggested to change the coding to a manual. Sweet! Easy enough. Pulled out my Rosstech and coded it to 00002. Now it’s misfiring at idle and slightly off idle. I’m assuming I’ll have to re do the soft coding and adjust the quantity adjuster? Some insight would be nice. I put the soft coding back to 00001 and it’s driveable and misfire is gone
