STRANGETDI
- Joined
- Sep 20, 2001
- Location
- East Hampton, CT
- TDI
- 2013 Audi A3 S-Line Premium Plus Quattro - APR Stage II
Hi all,
As I was doing my oil change today, I noticed all these tiny shards of metal all over the engine. It took me a little while to figure out what is was, but I found the source. It looks like the bolt/mount that the serpentine belt tensioner damper is attached to, snapped off and is vibrating all over the place when the engine is running. The broken part is rubbing against the pulley wheel and the shards are coming from both the pulley and the broken bolt/mount atached to the damper. I also saw that my coolant hose is being rubbed against and is slowing wearing away, as I can see the threads in the hose.
So I guess my question is:
Is my tensioner still OK, and what is the purpose of the damper.?I don't beleive I can reinstall it or a new one as the mount on the engine is broken off.
See pics of metal shards and busted damper:
Below you can see the coolant hose threads showing, just above the tensioner damper/piston thing.
this picture shows the break of the two pieces where the two pieces meet.
In this pic you can see that the side of the pully wheel is what is being rubbed against, by the broken mount attached to the damper. This is where the shards are coming from.
This is a pic with the engine running, I have a few videos but don't know how to post them here.
So what do you guys think?
Is my tensioner still OK, and what is the purpose of the damper? I don't beleive I can reinstall it or a new one as the mount on the engine is broken off. (update: it's not a broken engine mount.)
What should I do? The tensioner, damper and belt was replaced about a year ago by my mechanic. I wonder if he tightened the bolt to much that caused it to snap at the time or recently? Or something else? Car has 210,000 miles on it. Is the car driveable with out the damper? It seems so as it looks like it has been like this for a while now.
