wildn
My ALH seems to be running warmer, I've noticed temps at about 200-240*F max. I read both temp measurements from VCDS and my scan gauge. The worse its been was 243 and I pulled over immediately but there was no temp light on. I may just be overthinking, I know these run warm but how warm is too much.
I'm just a little stumped in the 3 months I did a full coolant flush and replaced the thermostat, ECT sensor, and the flange because the clipped snapped. Then about 400 miles ago I had my timing belt and water pump was done at a Trusted TDI mechanic, so even more fresh coolant was added.
The A/C blows cold and the fans kick on with the key on and the A/C button, is it the fan control module? The fuse doesn't look blown and the connection looks good.
