Nuje
- Joined
- Feb 11, 2005
- Location
- Island near Vancouver
- TDI
- 2015 Sportwagen; Golf GLS 2002 (swap from 2L gas); 2016 A3 e-tron
Recently did the timing belt on this car (2002 Golf, Stage4, VNT17, 02M - all the good goodies) - used Hepu water pump. Owner reported losing the coolant (OEM G13) coming through mountain pass (25km climb at ~4-6% grade).
First fix: Replace thermostat (OEM) - same symptoms.
Second fix: Tried early-open thermostat - car ran at 80C (from OBD) on the highway, but then still lost coolant under heavy load (12% grade driving for fun).
Put the new OEM thermostat back in - now it runs ~95C on the freeway (unusually hot) on a drizzly 12C day.
Thought the head might be lifting a bit under that load, so replaced the head bolts with ARP studs. Did the run up the 12% grade again - didn't lose any coolant...provided I backed off before the coolant temp went over 100C; first time doing that, I immediately pulled over and could see the coolant boiling - still at the same level I'd started at); I immediately turned around and started heading back down the mountain (10C outside, so it seemed to arrest the heating and cooled off to mid-90s quickly...down to 89C after a couple km going downhill).
Checked coolant level at the bottom of the hill - normal, where it was when I started.
Then I really pushed up the first few km (12% grade again) and this time, as coolant temp passed 105-107C, it was bubbling like crazy and level had gone down.
In all cases, the radiator fans never kicked on (they work fine if I turn on A/C), and the lower radiator hose that goes to thermostat neck / housing never got anywhere close to "hot". At most, it was warm-ish, compared to the upper hose coming off the flange at the transmission side of head which was always hot-hot.
Why doesn't that lower radiator-->thermostat hose ever get hot? Even when I have boiling coolant in the overflow ball and the upper rad hose is toasty-hot? Is my (new OEM) thermostat a dud? Is the radiator clogged up?
I read this in the manual, but it makes no sense to me (how does a hose collapse in a pressurized cooling system under high rpm?!)
I poured some coolant in the top hose and it did drain out the bottom (drain spigot), so there is flow, but I have no way to know / measure if it's sufficient flow through the radiator.
I also have trouble wrapping my head around the flow of coolant through the thermostat; what direction does the coolant flow through there once it opens?
Any thoughts, theories, suggestions, explanations, diagrams welcome.
